Old Aug 7, 2015, 02:21 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine Diagnostics
Print Wikipost
Truck won't start! 1999 5.2L
Old Sep 15, 2011 | 09:57 PM
RicksterB's Avatar
RicksterB
Default Truck won't start! 1999 5.2L
All of a sudden my 1999 5.2L Ram van won't start. I get 12V to the coil, spark from the coil and to the plugs. Rotor is spinning fine. I switched the ASD relay with the A/C one. I can hear the fuel pump cycle for 2 secs when i turn the key on and the CEL comes on for 2 seconds then turns off.
Unhooked the fuel line at the rail and gas sprayed out at me, so it looks like I have fuel pressure. I was gonna spray some ether in the throttle while cranking but the can went empty. I'll grab some tomorrow and try again. Also pulled the Crank angle sensor and it looks as clean as it did when I put it in there a couple of months ago.
The only things I can think of are the Cam Angle Sensor and the Computer. Anything else I should check?
Old Sep 15, 2011 | 10:04 PM
Mpi360's Avatar
Mpi360
Its the 5 volt wire.....Its all ways the 5 volt wire. Check it out.
https://dodgeforum.com/forum/2nd-gen...-wont-run.html
JEFF S.
Old Sep 15, 2011 | 10:18 PM
gdstock's Avatar
gdstock
JEFF S.
Tell me you didn't send him there! He is going to be so p*****!
Old Sep 15, 2011 | 10:24 PM
RicksterB's Avatar
RicksterB
Yeah, i was all ready to check the coil with my tongue! Come on, really though.
Old Sep 15, 2011 | 10:26 PM
rczanstke's Avatar
rczanstke
Is the engine not turning at all?
Turning but not starting?
Turning very slowly?
Old Sep 15, 2011 | 10:33 PM
gdstock's Avatar
gdstock
I have seen a number of threds/comments since I have been on this forum about coil issues. You may want to see if you are gettin fore to the plugs. Idk if that would throw a code or not.
Old Sep 15, 2011 | 10:38 PM
RicksterB's Avatar
RicksterB
Turns over fine, just won't start. I am getting plenty of spark from the coil and out to the plugs.
Old Sep 15, 2011 | 10:54 PM
Hahns5.2's Avatar
Hahns5.2
If you are getting spark, your cam sensor is fine, the ASD relay does not "arm" until it sees that cam spinning.
Is the spark weak (yellow)?
rczanstke's Avatar
rczanstke
I would try starting fluid.
Old Sep 15, 2011 | 10:56 PM
are you getting injector pulse? A noid light is the preferred tool here, but, a test light will work in a pinch. Just need to test one injector. Unplug it, hook the test light across the contacts, and crank the engine, if the test light doesn't blink, prolly cam sensor failed. (but, that should set a code..... one would think....)
Edit: If you are getting spark, the crank sensor is ok. Cam sensor controls when the injectors fire.
