gaaahhhhh this cant be happening
Old Sep 15, 2011 | 10:00 PM
redneck_ram's Avatar
redneck_ram
Default water pump, timing set, and plenum fix, with a broken intake bolt in the head
I bought a new serp belt the other day and got around to installing it this afternoon...well went to go to the store tonight and it shredded off...i couldnt find the belt anywhere in the road. Hopefully its under the hood somewhere... Any ideas as to why this happened? All the pulleys looked fine and i ran the truck for a few minutes after install and it was perfect...now i dont have a way to work in the am....any help is appreciated thanks guys!!
Old Sep 15, 2011 | 10:24 PM
rczanstke's Avatar
rczanstke
I would double check that no pulleys are seized. Also, is your tensioner okay? It could just be a defective belt, but that seems very unlikely.
Old Sep 15, 2011 | 10:26 PM
Mpi360's Avatar
Mpi360
My thoughts are a Goodyear Gatorback ?
Old Sep 15, 2011 | 10:52 PM
if you had the belt not quite aligned on one of the pulleys, that is precisely what would happen......
Old Sep 15, 2011 | 10:59 PM
gdstock's Avatar
gdstock
Is the Goodyear Gotorback the best belt to use? I am going to replace timing set and water pump when I install modded kegger, and will rpobably replace hoses and belt while I have it down.
Old Sep 15, 2011 | 11:05 PM
Mpi360's Avatar
Mpi360
I read some were(no experiance with one) that the GatorBack wil shred in no time on outr truck's.
Old Sep 15, 2011 | 11:37 PM
redneck_ram
it was a cheapy from advance. but i had it aligned perfectly, and it was tracking good when i did a start up test. what pisses me off the most is when the belt let go it took off my oil dipstick handle. how and i going to get that sucker out of the tube?its recessed about 1/4 inch in the tube. found the belt nicely wrapped around the fan clutch. going to throw the old belt on just to get me to work and then to the parts store to get the belt warrantied and get a new tensioner. thinking the tensioner may be the culprit! we will see....
i literally drove less than 5 miles from my house when it happened. let me tell ya, no power steering, and using as little lights as possible, it was a fun drive home!
Old Sep 15, 2011 | 11:46 PM
crazzywolfie's Avatar
crazzywolfie
this probably make you miss the old school v-belts. back when the power steering and alternator where on separate belts. it is pretty hard to kill a v-belt unless there loose.
Old Sep 15, 2011 | 11:51 PM
gdstock's Avatar
gdstock
If you mention the tensioner, they probably won't warranty the belt. May want to get tensioner at another store!
Old Sep 16, 2011 | 12:04 AM
jasonw's Avatar
jasonw
Site Moderator
Uh, no it will not. Not sure who stated that, but they were incorrect. I have been running a Gatorback on my truck for the past 5000+ miles or so, no problems at all. The tensioner and water pump I bought, on the other hand, I am having second thoughts about...
