figured out my vibration problem.....transmission HELP!
Old Sep 29, 2011 | 06:58 PM
  #41
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by 95gaser360
well is it worth replacing if there is no slop in it?
Not wanting to spend your money, I still say yes. I've seen to many time's any kind of bearing or even ujoint for that matter check out ok.(without stress/load on it) Only to replace it and solve the problem.
And btw, you can eliminate it altogether and put a regular drive shaft in.
Old Sep 29, 2011 | 07:57 PM
  #42
95gaser360's Avatar
95gaser360
your refering to a one piece driveshaft?
Old Sep 29, 2011 | 08:31 PM
  #43
zman17's Avatar
zman17
yup.....
Old Sep 29, 2011 | 08:37 PM
  #44
95gaser360's Avatar
95gaser360
did 1 tons ever have those?
Old Sep 29, 2011 | 09:14 PM
  #45
what cab/bed length ya got?
Old Sep 29, 2011 | 09:16 PM
  #46
95gaser360's Avatar
95gaser360
ext cab long bed
  #47
That's prolly why it has a two piece then.....
Old Sep 29, 2011 | 09:18 PM
  #48
zman17's Avatar
zman17
OK, why would you ask that? To make me look stupid? LOL I bet it's because you have a 3500 right? Of course you have no info about your truck in your sig or profile. Doesn't matter, I assumed it was a 1500, and some early models had a 2 piece shaft that is replaceable with a one piece even from the dealer.
Old Sep 29, 2011 | 09:30 PM
  #49
95gaser360's Avatar
95gaser360
yep 3500. how much backlash should the rear diff have? dana 80? anyone know?
Old Sep 29, 2011 | 10:04 PM
  #50
zman17's Avatar
zman17
Not off hand, but if you look in the manual from the FAQ section I bet you'll find that info.
