Noise during acceleration
Old Oct 13, 2011 | 06:31 PM
  #31
BackwoodsRam's Avatar
BackwoodsRam
dang man. my t-case went out 3 weeks after i bought my rig and the dealer woudnt touch it
Old Oct 13, 2011 | 09:34 PM
  #32
gdstock's Avatar
gdstock
Originally Posted by DodgeSporter
Just got the news, $1300 fix all shot except the axels. And the dealer I bought it from has mysteriously lost the ability to return calls.
I'd have my a** parked at his shop door when they arrived in the morning, and ask, "can you hear me now?"
Old Oct 14, 2011 | 03:08 PM
  #33
DodgeSporter's Avatar
DodgeSporter
I got $500 from them, more than I figured I would have gotten.
Old Oct 17, 2011 | 10:53 PM
  #34
DodgeSporter
Got the truck back today and freaking night and day difference. Now my OD off light is on. The shop doesn't do transmissions but they said it looks recently rebuilt but it isn't supplying the pressure it's suppose to be? Not sure if I repeated that right but does that make sense to anyone?
Old Oct 17, 2011 | 11:43 PM
  #35
Put your truck info in your sig line, and your profile. That way, it's easier to help you.
What year is your truck?
Old Oct 18, 2011 | 12:05 PM
  #36
DodgeSporter
huh, aparantly if you post from you iphone it doesn't put your signiture in.
Old Oct 18, 2011 | 12:44 PM
  #37
Ok, 99. Yep. You have the governor pressure sensor and solenoid. They are notorious for getting gummed up, and then not working properly. You could drop the pan,and see what ya got, and if it's rather cruddy, remove them, and clean 'em, or, simply replace them.
Verify all electrical connections at the trans first though. Are you getting any codes?
Old Oct 18, 2011 | 02:31 PM
  #38
DodgeSporter
P0751 O/D Switch Pressed (Low) More Than 5 Minutes
Thats the code i am getting. I got the tuner in this morning and updated it, so im guessing it wiped any other codes it was getting.
Old Oct 18, 2011 | 02:59 PM
  #39
That would indicate that something is shorted. O/D switch is just a momentary switch that tells the PCM you don't want overdrive until the next key cycle. (or, you press the button again.) If you press the button, does anything change? If not, time to start checking wires.
Old Oct 18, 2011 | 05:28 PM
  #40
zman17's Avatar
zman17
Retired Moderator - RIP
Add the basic info to your profile also. It will/should show up when you post from a cell phone.
