4x4 vacuum lines
I have a 2001 1500 4x4 and one of the hard plastic vacuum lines from the transfer case to the steel line is broken. I have temporarily fixed it with vacuum hose. Does anyone know where to buy the hard plastic vacuum line? I have searched the internet and found only the steel lines.
lol naw man you can make one that locks and unlocks, next time i go to my dads im gonna turn mine into one
Trending Topics
you need a welder and a hacksaw/cutoff wheel/sawzall
1. you disasembel the CAD assembly.
2. cut off the vaccum acctuator
3. weld a long enough thick enough rod to the actuator arm(the part the fork goes on)
4. weld a handle on the end of the arm that is outside the assembly
5. reassemble CAD
6. drill a hole for a retaing pin, small bolt, etc. in the locked and unlocked positions
7. reinstall CAD assembly on the axle
5. reassemble CAD
