how in the hell do you pull the harmonic balancer off!!!!
Old Oct 10, 2011 | 11:34 PM
  #21
aim4squirrels's Avatar
aim4squirrels
Originally Posted by 71dodge
i got it off after alot of cursing.
I told you. And everybody just brushed my comments off like it was crazy talk.
Cussin' gets **** done.
Old Oct 11, 2011 | 02:38 AM
  #22
TheycallmeLaramie's Avatar
TheycallmeLaramie
I definitely Second your notion aim4, cussing at the thing definitely makes me feel stupid for not being able to get it off, and in turn makes me want to get it off even more. Just dont add rage into the combo unless your smacking out your front end suspension. cussing, pickle fork, sledge, bigger sledge, and rage. ahhhh memmmmories
Old Oct 11, 2011 | 04:58 AM
  #23
candymancan's Avatar
candymancan
You need to be carefull taking it off and putting it back on, if you put it on wrong and start getting frustrated you can **** your bearing up in the engine.
Old Jul 29, 2015 | 10:49 PM
  #24
matt396's Avatar
matt396
Get some steel rod and jam it between the puller and the outer pulley then work the puller regularalyand it will run up un the pulley and pull out
Old Jul 29, 2015 | 10:55 PM
  #25
matt396's Avatar
matt396
Default you need a few pieces of steel
Old Feb 20, 2021 | 06:53 PM
  #26
Icepike's Avatar
Icepike
Default Reinstall
This post really helped me. Thank you all for helping out. How did you reinstall the harmonic balancer?
Old Feb 20, 2021 | 07:27 PM
  #27
Put it on, so the keyway lines up, push it on as far as you can, then just use the bolt to draw it in the rest of the way.
Old Feb 20, 2021 | 08:29 PM
  #28
Icepike's Avatar
Icepike
Thank you
