help wake up my ram 1500
Old Oct 11, 2011 | 02:24 PM
DodgeSporter's Avatar
DodgeSporter
I have a 99 ram 1500 5.9. Felt a big differance after the plenum repair. Make sure to do the 02 sensors too otherwise you wont notice it. I have my SCT on the way, I'll let you know what i think once it shows up in the next day or so. I have heard it sounds like a completly different truck.
Old Oct 11, 2011 | 03:42 PM
BigBlue83's Avatar
BigBlue83
what are you refering to about kegger mod? i plan on doing my 98 sport 5.2 plenum and want to do a couple cheap mods in the process. also why would it be a good idea for the water pump?
Old Oct 11, 2011 | 04:12 PM
If you do the timing chain and gears (which is recommended on a high mileage motor), the pump needs to come off anyway. They aren't that expensive, so, replacing it at the same time just makes good sense.
Kegger mod is effectively shortening the intake runners, by cutting them down an inch or so inside the plenum. Also, removing the center divider, but, that's not an issue for you, as your shouldn't have it anyway. Doing the mod just moves the power band up a couple hundred RPM. Considering how quickly the kegger intake runs out of steam (at about 4K RPM, drops off pretty bad...) doing the mod 'helps' in the upper RPM range some, without really compromising bottom end.
I think doing the timing set on my truck was THE best 'maintenance' item for improved power/driveablity I have done to my truck.
Old Oct 11, 2011 | 05:51 PM
8uzzsaw's Avatar
8uzzsaw
A good idea of what to do to your truck would be to look at everyones signature and pick out the most common mods listed. If that many people are doing it, it has to be good! Or marketing is paying off! Lol
Old Oct 19, 2011 | 11:54 PM
fargo39's Avatar
fargo39
hey dodgesporter did you get your sct installed yet. i have a 01 1500 with a 5.9. i am going to do the kegger mod, was not sure if it was a worth while mod but seems everyone is happy with the results. if the sct tune works and maybe get some mpg improvments i am going to get one ordered up as well
Old Oct 20, 2011 | 06:21 AM
lastrights's Avatar
lastrights
There's a lot of threads for power , use search .gears are best mod to do
Old Oct 20, 2011 | 09:46 AM
Sheriff420's Avatar
Sheriff420
4.10 gears gave my truck the most noticeable kick in the butt that it needed.
Old Oct 20, 2011 | 09:55 AM
lastrights's Avatar
lastrights
https://dodgeforum.com/forum/2nd-gen-ram-general-discussion-non-tech/307073-easiest-least-expensive-ways-to-add-power-performance.html same thread going on right now
Old Oct 21, 2011 | 09:21 AM
fargo39's Avatar
fargo39
i noticed know one mentioned when they do the timing chain they don't put the timing chain tensioner upgrade in. my truck has the 3.91 gears going to 4.10 did you guys lose a bit of mpg on the highway. i know the 5.9 wasent the best on fuel to begin with and most trucks have the aerodynamics of a sheet of plywood.
Old Oct 21, 2011 | 09:25 AM
When I did my timing chain, I didn't really see the need for the tensioner. The double roller feller is a bit more resistant to stretching so, I didn't worry about it. Granted, these are some of the longest timing chains I have seen in a motor that ISN"T overhead cam.....
Depending on what size tires you run, you may see mileage go UP with the deeper gears.
