Please help
Old Oct 14, 2011 | 08:08 PM
  #131
gdstock's Avatar
gdstock
Originally Posted by 71dodge
well i bent some valves. heads are coming off now. oh well
I have never seen a push rod get bent except when a piston slaps an open valve, and I have not seen it not bend calve stem. Hopefully it did not crater the top of the piston. Check each cylinder closedly for piston damage and any possible debris around piston along cylinder wall and for cylinder scoring, as well as damage to valve seats.
Old Oct 14, 2011 | 08:22 PM
  #132
zman17's Avatar
zman17
Retired Moderator - RIP
My theory is , the timing was so badly off, that when the piston came up and the plug fired, the wrong valve was trying to open at the wrong time. (and this happened within milliseconds of initial start up) . I only say this, because I'm pretty positive, that no way the pistons hit the valves. If I'm wrong I'm wrong, but I don't think so.
Old Oct 14, 2011 | 08:24 PM
  #133
kejobe's Avatar
kejobe
Your wrong.....maybe.
Old Oct 14, 2011 | 08:31 PM
  #134
gdstock's Avatar
gdstock
And if you are right, OP saves some money!
My experience has been different - but when I was 16 to 19 years old, my dead used to say I could tear up an anvil with a rubber hammer.....and he was right! I floated valves on more that one ride....
Old Oct 17, 2011 | 03:20 PM
  #135
71dodge's Avatar
71dodge
i bent each and every single intake valve on the heads and i think 2 or 3 exhaust vavles. go figure theres a half inch cap between the valve and the head and thats closed
Old Oct 17, 2011 | 07:54 PM
  #136
Wow. Ok, so much for these being spin-free motors eh? Definitely keep that in mind. Sorry you had to be the one to figger that out.
As opposed to replacing the valves, might wanna just replace the heads, Clearwater has a fully assembled head for under 300...... not sure how much you are going to end up paying for valves, and head work.... new heads just might work out cheaper.
Old Oct 17, 2011 | 08:19 PM
  #137
zman17's Avatar
zman17
Are there signs on top of the pistons that the valves hit them? I doubt it. The timing was so bad off that the valves were opening at the wrong time , and compression did the damage. JMO as previously stated.
Old Oct 17, 2011 | 08:25 PM
  #138
CPTAFW163's Avatar
CPTAFW163
That's only because the first few guys that posted were/are wrong.
Ah, it was confusing to tell who was correct in that chatroom.
Old Oct 18, 2011 | 08:06 AM
  #139
71dodge's Avatar
71dodge
im buying a new set of odessa heads for 420 with free shipping. by the time i get done with the heads that would be the easiest and cheapest way to go.
Old Oct 18, 2011 | 08:52 AM
  #140
8uzzsaw's Avatar
8uzzsaw
That was an expensive lesson to learn, sorry about your luck man!
