Won´t get really warm..?
Old 10-14-2011, 06:12 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
Get a new radiator cap also. 16lbs.
And please read this thread https://dodgeforum.com/forum/2nd-gen...e-tragedy.html
Old 10-14-2011, 10:01 PM
CPTAFW163's Avatar
CPTAFW163
CPTAFW163 is offline
How is your heat? My factory gauge reads about 180, but the air is still hot when I use the ehat. However, it is not freezing out in Indiana yet. I remember my heat was not so good in just above freezing temps in Arkansas. Even threw the "engine too cole too long" code.
Are you getting a CEL (Check engine light). Because if you are not, then I would not even worry about it. But you can throw about 30 bucks in parts and see what happens.
I would start with: Ranked in order of cost
1 Radiator cap
2. Thermostat
3. Temp sensor (From dealer, not autozone/napa/oreilleys/etc)
Do them separately and narrow it down.
The thermostat is "easy" to change, but you need to take off the alternator and AC compressor (and both brackets). So it is more of a "assemble/disassemble" thing. Just be sure to put back the ground wires.
Quick Reply: Won´t get really warm..?
