1997 dodge ram 1500 4x4 tranny problems!
Old Oct 24, 2011 | 06:09 PM
jrandal's Avatar
jrandal
Not yelling,sorry!
Old Oct 25, 2011 | 11:46 AM
jrandal's Avatar
jrandal
Fixed it.It had a shorted relay that put the computer in limp mode,And when i was doing the on/off ignition three times it takes the computer out of limp mode and that's why it worked after doing that,Replaced relay,Disconnected battery to reset computer and all is good know,Thanks,Hey You for your help!!!
Old Oct 25, 2011 | 11:50 AM
zman17's Avatar
zman17
Retired Moderator - RIP
How come you didn't just do the "key trick" to reset the pcm?
Old Oct 25, 2011 | 12:33 PM
jrandal's Avatar
jrandal
That will just take it out of limp mode,It won't reset the check engine light to go off!
Old Oct 25, 2011 | 12:38 PM
zman17's Avatar
zman17
Ok thanks J, just curios that's all.
Old Oct 25, 2011 | 12:46 PM
jrandal's Avatar
jrandal
No problem,I learned a lot from this little problem,Learned-don't always listen to a code reader,How to change the solenoid pack,governor sensor,and solenoid,How to tighten bands on tranny,and how to get it out off limp mode,And or what the hell limp mode is!LOL!!! Oh ya if the computer senses a short in the relay's it will lock the computer in limp mode and will make it start off in 3rd gear!
Old Jun 18, 2012 | 10:21 PM
DLMcpherson's Avatar
DLMcpherson
Which rely was bad and where was it located??
Old Jun 18, 2012 | 10:31 PM
Trans relay I should think, it's in the PDC, right behind the battery, under the hood.
