Lack in power
Old 10-31-2011, 09:00 PM
blackbeasst's Avatar
blackbeasst
blackbeasst is offline
if you drive just around town don't expect 16 or more! i'm still sittin at about 11 after plenum/tune up and y-pipe
Old 10-31-2011, 09:28 PM
lastrights's Avatar
lastrights
lastrights is offline
Being a 01 it has a death flash , its a overwrite of the pcm that kills your performance , dodge did this to fix minor problems but problems were still there . They dis it too elimanate ping of a blown plenum
Old 10-31-2011, 09:40 PM
BackwoodsRam's Avatar
BackwoodsRam
BackwoodsRam is offline
id be happy with 10 or 11 mpgs i only get about 8 but thats with 37's on 3.92 gears
Old 10-31-2011, 10:02 PM
gdstock's Avatar
gdstock
gdstock is offline
Originally Posted by niceandeasy
I know what it is. There seems to be very little oil inside the intake more like a film. I been thinking of cutting my cat out but what is the pros and cons of running no cat.
Back to the original question: There should not be any oil on the plenum plate. And this oil is what casues the cat to clog and fouls upstraem O2 sensor. The solution is to replace plenum plate with 1/4" aluminum plate and new felpro gasket. Plate can be found on ebay for $50. Replace cat (or cut out, and Heyman said, depending on regulations where you live) and replace O2 sensor, and get a tune to get rid of death flash (I went with SCT from hemifever.com).
It is also recommended to replace water pump and timing set as you are down to this when you pull the intake to repair plenum. Not that much money for the peace of mind and improved performance.
This will restore the power that you are missing. Money well spent imho.
Old 11-01-2011, 10:00 PM
biggreen2500's Avatar
biggreen2500
biggreen2500 is offline
what are you guys talking about the death flash on the 2001 dodges
i own a 2001 dodge ram 2500 4x4 360
Old 11-01-2011, 10:17 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,282 Likes on 3,029 Posts
Death flash was a bandaid fix for other problems the truck had. Yours prolly came with it from the factory....... An SCT tuner would probably REALLY surprise you. Not only does it kill the death flash, it also disposes of torque management. (dodges answer to putting in weak transmissions.....) There is a thread in the FAQ section that goes into more detail.
Old 11-01-2011, 10:19 PM
biggreen2500
do you know the title of thread by chance cause if it would make a big differnace i might have to get it then...
Old 11-01-2011, 10:24 PM
HeyYou is offline
Here ya go.
Old 11-01-2011, 10:50 PM
biggreen2500
yeah i'm gonna get a SCT as soon as my other car sells.... i
Old 11-01-2011, 11:21 PM
Wombat Ranger's Avatar
Wombat Ranger
Wombat Ranger is offline
Back to the original thread changing topic: I get 13.5 mpg around town with 3.55's and 33's with a stick and I'd be happy with 25.
Quick Reply: Lack in power
