should i spool it
Old Nov 3, 2011 | 03:39 PM
biggreen2500's Avatar
biggreen2500
Default should i spool it
so i was reading randy's ring and pinion website... and they make spools for our trucks i have 60 in the rear..
they say the spool shouldn't be used on street driving trucks... i know when you have lockers it chews up your tires is that the say reason why they say that about the spools or could i cause some major damage to my rear if i spool it and still drive it on the street
Old Nov 3, 2011 | 04:13 PM
At least a locker has the ability to unlock...... a spool on the street would be really bad for your tires, and would be rather hard on all the rest of the differential parts. Spend the money for a good locker.
Old Nov 3, 2011 | 04:18 PM
biggreen2500
yeah i thought so... lol i'm gonna hold off on lockers tho case i want to rear gear to like 4.56 with my 35s
Old Nov 4, 2011 | 07:34 PM
dhvaughan's Avatar
dhvaughan
when driving on the street the rear tires need to 'differentiate' or turn at different speeds in order to go around curves. a locker will unlock automatically under turning stress to allow this. a locker won't overly wear out the tires. (it does a little but not a lot).
a spool stays locked all the time, which forces one of two things to happen - either the inside tire spins and hops and jumps, or worse - in wet weather the tires break loose and you spin out and end up in the ditch.
do not put a spool in a street driven truck.
Old Nov 4, 2011 | 08:07 PM
stewie01's Avatar
stewie01
There are some Detroit Locker's for the Chrysler 9.25 rear end, cost form SummitRacing is just over $600, plus shipping.
Old Nov 5, 2011 | 03:29 AM
biggreen2500
i have dana 60s in my truck stewie
Old Nov 5, 2011 | 11:54 AM
Wombat Ranger's Avatar
Wombat Ranger
Parts for Dana 60's are the easiest to come by, and there is a bigger market for them then anything else, due to their popularity. Detroit might be even cheaper for it then a 9.25.
Old Nov 5, 2011 | 04:50 PM
stewie01's Avatar
stewie01
My bad biggreen, apparently I wasn't paying attention. $609.95 for the Dana 60.
http://www.summitracing.com/search/B...ew=ProductName
Old Nov 6, 2011 | 12:37 AM
biggreen2500
yeha i figured lol i think your truck has a 9.25 so maybe that what you were thinking....
no worries bro.... i'm gonna wait on the axle stuff then cause i wanna rear the truck and do front and rear locker and get my hubs put in
