not looking to fix the truck if i buy it. i'm just looking for a cheap fix like a additive to the coolant that will seal the block so i can get a few months of fun out of the truck
and i just want to know what you guess have used in the past
Throw some crap in it before you buy it and see if it works .
But, if it's been run with a bad head gasket, it could also need bearings in the bottom end due to watered down oil. I doubt the sealant crap will work though. It almost never does.
