help with Anti freeze leak
So this morning i go out my house and go to get in my truck, i happen to look down and see a little puddle of anti freeze... if your facing the front end its on the left side. I tryed to see where it was coming from couldnt really see anything however what i did notice is on the lip where the oil pan meets the engine there was a sludge mix of oil and anti freeze. I dont know if its all related or if the anti freeze sat on some old build up and made the sludge. I know that my resevoir for anti freeze doesnt hold anything very well so theres a problem somewhere. Ive had the truck for bout three months but never had sighns of a leak. Once in a while i would smell a sweet smell while driving but always thought it was from a tranny that needs work .... my truck has kinda hard loud shift when putting into drive or park some times and has a problem accelerating from full throttle. Its fine when i begain a slow acceleration and steadily add pressure to the gas peddle. Ive heard alot of talk about plenum and havent been able to check if mine already had a plenum kit or if it needs one. as far as the acceleration issue I dont know if my cat is clogged or if its a plenum problem or a slipping tranny or what. (theres alot of rust on the under carriage) Is it possible that the anti freeze had an internal leak hence the smell and crappy resevoir causing loss of power than that internal leak just became a external. Or does my truck just have a slew of issues? I did my oil about 2400 miles ago and bout 6 days ago i started to hear my lifters when excelerating so i checked my oil and it was low. now this... I dont have much experience yet i enjoy fixing/improving my truck ive done spark plugs spark plug wires oil changes tranny filters and transfer case fluids starters and brakes thats the brunt of my experience so if any one has any help id Truly Appreciate it. I cant afford a shop and my truck is everything to me.... Thank You again
Sorry to break it, but as you suspect, you have aslew of issues. Coolant will ot cause the loss of power, unless a head is cracked, but I think it is most likely the plenum. Check and see if ther is oil inside looking through the throttle body.
Coolant and oil where you indicated may be the timing cover housing. You may get lucky and it may be leaknig at the tstat housing and you can only see it lower. See below:
I assume that since you did not mention that there was water in the oil that it was oil only.
tomorrow at work when im at lunch i will take the hat assembly off and a flash light and look in the manifold... One thing I forgot to mention is when i first got the truck it whent to the shop and they said that one of the freeze plugs had been replaced but not the other one on the same side... i was just looking for a DIY on the freeze plug. Maybe the puddle came from there???
as for the power i do believe it is one of two things The bands adj. and/or governer solenoid needs to be cleaned and the plenum. when i first got the truck i was inspecting it and cleaning it while doing that i put a whole in the muffler. the bed started to get hot! and had a burn mark my tranny started acting up i checked the fluid it was dark. so i changed the filter but didnt do the bands or clean the solenoid. however the truck stopped acting funny when driving. by funny i mean i would be at a steady speed and it would drop out of gear and like go back into gear it would stay driving but you could hear and feel it. after i changed the filter and put ATF4 it stopped doing that and the color was normal. i fixed my muffler and the color stayed normal.
Blown plenum gasket can suck oil into intake manifold, and into combustion cylinder. Here is what mine looked like"
If you look down through throttle body with flashlight you may see oil inside. Not all of them have as much as mine did.
This oil not only fouls plugs, as it does not burn completely, it clogs cat and destroys O2 sensor.
Trending Topics
