vacuum leak @ hvac controls?
Old Nov 30, 2011 | 08:27 PM
cutthroatxxx's Avatar
cutthroatxxx
Default vacuum leak @ hvac controls?
Hello all!Im having issues with my hvac.I can only get it to blow out of the dash vents nomatter where I set the controls to&I can hear a leak or sucking right behind the top position ****.Since my dash is cracked I can see it all of the lines are on there.Could that clear rubber piece of gone bad?What can I do to fix this.Thanks in adcance.
Old Nov 30, 2011 | 09:57 PM
cutthroatxxx
Mcan I replace the whole controls?
Old Nov 30, 2011 | 10:21 PM
The controls themselves are not serviceable, so, if they are the culprit, ya don't get a choice, gotta replace the whole thing.
See if you can push the clear plastic thing on there better, and also check and see if any of the lines there are broke.
Old Nov 30, 2011 | 10:27 PM
cutthroatxxx
I'm guessing it is that clear plastic piece because when I push on it. It quiets a tad bit.Any idea where I can order that part&what it would be called?
Old Nov 30, 2011 | 10:31 PM
Parts manuals are available in the faq section..... I am not sure you can get just that, or if you would have to get the entire harness. Try pulling it off, smearing some Vaseline in there, and see if that doesn't help.
Old Nov 30, 2011 | 11:07 PM
jswain's Avatar
jswain
If that fails, that sounds like a good part to get at the junkyard. The dealer, if they sell that one piece, the whole unit together, or whatever, will probably be ridiculously expensive on something like that.
Old Nov 30, 2011 | 11:36 PM
cutthroatxxx
Anybody got a link on how to replace the whole thing?Im guessing its whatever is behind. That clear piece.Also thought I should mention when you turn the truck off you can still hear the leak/sucking for about 5 seconds.
Old Nov 30, 2011 | 11:59 PM
jswain's Avatar
jswain
I think the clear plastic piece behind the HVAC switches is attached to several vacuum lines that run to a junction block (another clear plastic piece), if I remember right when I had the dash out to replace the heater core in my 98.
Old Dec 1, 2011 | 12:08 AM
cutthroatxxx
No I mean what is behind the clear piece when you take it off of the controls
Old Dec 1, 2011 | 12:25 AM
jswain's Avatar
jswain
Don't know that off hand. I don't think there's anything between the junction block (clear plastic piece) and the controls. What is inside the controls? Don't know that. I assumed you'd have to break it to take it apart, basically.
