Thermostat Question
Old Dec 1, 2011 | 06:45 PM
leorov's Avatar
leorov
Question Thermostat Question
needed a new thermostat (low heat from heater) replaced with 160 thermostat.
everything is fine but on way to work CEL pops on.. And to top it off for some reason none of the readers @ the auto stores pick up any info at all, like they cannot link..
1. is 160 triggering a code?
2. why will readers not work?
1996 Dodge 1500 5.2 thanks leo
Old Dec 1, 2011 | 06:50 PM
Bens5.9l4x4's Avatar
Bens5.9l4x4
160 is too low its probably throwing a "running cold for to long code" change it back to factory which is a 192. It will run better with it anyhow. And u will probably get some bad replies to this seeing as how u could have searched and found out anything u wanted to about thermostats good luck.
dlyter09's Avatar
dlyter09
Dont run the 160. It causes a code to be thrown. Something about engine to cool or something. Go to a 195 or 180 and that should fix your problem. Low heat from the heater could be due to a clogged heater core. Either way move up to a 180 or 195 and see if that cures your problem.
Old Dec 1, 2011 | 06:54 PM
stewie01's Avatar
stewie01
Just go back to the 195*, unless your running a tune there isn't much to benefit from the 180.
Old Dec 1, 2011 | 06:56 PM
leorov's Avatar
leorov
Just searched (please don't beat me up) will switch back asap. 180 or 195 correct. heat working great now..
Old Dec 1, 2011 | 06:58 PM
dlyter09's Avatar
dlyter09
Unless your tuned dont go with the 180. Just stick with the 192
Old Dec 1, 2011 | 07:02 PM
stewie01's Avatar
stewie01
Just replace it with the stock 195*. These trucks aren't designed for the 180 unless your running a tuner, like an SCT Tune.
I think some people on here run a 180 without a tuner and without any problems, but it's probably hit or miss.
Old Dec 1, 2011 | 07:19 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Change your oil.
Old Dec 1, 2011 | 07:31 PM
crazzywolfie's Avatar
crazzywolfie
Originally Posted by drewactual
I thought I would collect this information and put it in such a form that an admin or mod could move it over to the FAQ if they see fit..
Why would you want to use a lower temperature rated thermostat?
Engines get hot.. Duh.. A hotter engine is more likely to allow detonation of your air+fuel mix BEFORE spark is applied than a cooler one.. The cooler the engine, the less likely you will get pre-detonation. This is the reason to use a cooler thermostat, but there are two major reasons why folks would consider such..
1. Eliminate or reduce pre-detonation, a.k.a. 'pinging'..
2. Advance ignition timing in a safer (cooler) environment..
When would you want to use a lower rated temperature thermostat?
Only when you have adjusted ('tuned') the PCM to curve fuel would you be reaping any benefit from using a 180* 'stat.. Until you 'tune' the engine, you are wasting fuel, and layering crap on your o2 sensors and cats, which will shorten their lives.. The engine may give the impression of running better, but that's just what rich engines do- they feel smoother.. Don't be fooled, you're robbing yourself of power..
The PCM is looking for an operating temperature of 195*, and when it's having a hard time achieving that, it adds fuel.. Why? Cooler air+fuel charges are harder to ignite, so, it adds more catalyst (fuel) to make the explosion more possible..
Expectations in power while using a lower temperature rated thermostat:
gotta look at this from two vantages....
With a TUNE, curving fuel and advancing spark-
economy: look for similar fuel economy as you had with the OE 195* thermostat, or, just a little less economy..
performance: look for gains in power production and improved throttle response.. you may pick up as much as 5~10 ponies using a 180* 'stat, and it's all because of advancing timing on a denser air+fuel load... Think of it something like this- the piston moves north, squeezing the a+f into a volatile little ball, and hits it with spark to make it explode.. On an engine that is warm(er), it is only safe to do so just after the piston reached top dead center, and starts heading south- otherwise, you could have pre-detonation, which is the explosive force pushing against the mechanical revolution of an engine.. Bad stuff, yo.. But, if you can hit the a+f load with spark either RIGHT at top dead center of the pistons travel, or SLIGHTLY before the piston hits TDC, (to give the piston time to complete it's travel and reach north just as the BOOM REALLY starts to expand), you've effectively INCREASED compression of the engine in comparison to an engine that hits spark AFTER the piston starts heading south.. The smaller, tighter, denser that little ball of a+f is, the more powerful it's explosion, the more power you put to the ground, and again, it can be somewhere between 5~10 ponies worth across eight cylinders...
WITHOUT a tune:
Economy: look for a drastic fall off in economy while using a cooler 'stat without a tune to support it. The engine will squirt excess fuel in effort to make the BOOM more likely to happen (avoid misfires)..
performance: look for richer conditions which will make your engine run smoother, but less powerfully.. contrary to popular opinion, a rich engine DOES NOT produce more power.. It produces less than the 'perfect' a/f mix of 14.7:1... venturing to either side of that 14.7 will result in loss of power..
Why do our trucks come with a 195* thermostat?
emissions standards. The warmer the engine, the more 'burn off' of excess gases..
Why not use a 160* thermostat instead of a 180* thermostat, if the 180* is better than a 195*?
there is a point somewhere between 160* and 180* that your PCM will start tossing codes your way.. You will get a P1281 "engine too cool for too long".. Even without a 'tune', your engine likely won't kick this code with a 180*, but it certainly will with a 160*..
there is also a temperature point where your engine is most efficient at burning all that fuel, and it can only advance timing so far too.. The point of maxing the advance is achieved with the 180*. Any reduction in operating temperature beyond that point, is going to have adverse reaction in emissions.. which, in that extreme, will have adverse reaction in performance too.
Will using a 180* thermostat really make the engine run cooler?
Yes.. and, No..
Your engines operating temperature is going to be dictated by the overall health and configuration of your entire cooling system. The volume of coolant, the velocity and volume of coolant movement, and the surface area of your heat exchange have more impact on your operating temperature than the 'stat does.. However.. Your 'stat opening sooner allows your engine to start cooling quicker. If you're not under load, chances are the 'stat will open and close, regulating temperature to a degree you never exceed 190*.. If you ARE under load, such as climbing a steep and sustained grade, towing, or hauling, your 'stat (no matter which one) will be wide open and the rest of your cooling system will be responsible for your operating temperature..
A 'tuned' engine running a 180* 'stat will allow the advancing of timing ONLY when the operating temperature hovers in the sweet spot of 175*~190* or so.. If you're pushing/pulling/hauling, or running the purple crap out of your truck, the PCM is going to sniff the operating temperature via temperature probe, the a/f via o2 sensor, and the air intake temperature via IAT, and adjust timing and a+f ratio accordingly.. In other words, toss the tune and the benefit of a 180* out the window..
Adverse reactions to using a 180* thermostat:
without rehashing the above, look for cooler heat from your vents... 'round about 15* cooler, if you can kinnit. The coolant that charges your heater core is cooler, and therefor you get less heat out of it... Us southern fellers don't mind that a lick, but you yanks may not appreciate that too much..
Is it worth it?
with a tune? yes...
without a tune? no...
long term effects:
hard parts and pieces in your engine are designed to live in a certain temperature range. There is some debate that the cooler 'stat never allows those parts to operate in the environment for which they were designed.. The (insert fancy metallurgical word here) coating on hard parts will fail over time.. but, we're talking a LOT of time..
Inspections and emissions:
with a tune: no worries.
without a tune: you is gonna fail, yo.. too rich.. ruh-roh..
I think that is all.... Please add as you see fit, and we'll solicit HeyYou to clean it up, take ownership, and add it to the FAQ..
Thanks.
Old Dec 1, 2011 | 07:34 PM
LoneWolfArcher's Avatar
LoneWolfArcher
Not sure why the reader didn't read the code, but you don't need a reader. Just turn the key to accessory twice, then a third time to see the code read out right on the odometer.
