Rear lift questions
Old Dec 1, 2011 | 09:37 PM
kejobe's Avatar
kejobe
Default Rear lift questions
I installed a Hell Bent 2" level a couple months ago. Ever since, it looks as though it's now high in the front. Though it may just be me.
All I want to do is put a 1" block in the rear, and all I've come up with is aluminum. Not doing that. Being said, I have access to a machine shop so I can make my own.
On to the questions,
1) Is there a taper required for a 1" block?
2) What length block? Same as stock?
3) What diameter center pin?
Old Dec 1, 2011 | 10:27 PM
I would grab a stock block, either one of yours, if you have something else to drive for a bit, or, grab one from a junkyard, and take the measurements you want, then, make a block that is one inch taller than the stock block, and install that IN PLACE of the stock blocks. (have to get creative for the bump stops....) I don't like stacking blocks. It just makes me nervous.
Old Dec 1, 2011 | 10:46 PM
kejobe's Avatar
kejobe
I may. Will have to wait till summer though, since the elky wont leave the garage till then. I cant have any downtime with the truck now.
Old Dec 2, 2011 | 02:07 AM
97tn4x4's Avatar
97tn4x4
There are tons of places that sell a 4" block. If you make your own be sure to taper them for your pinion angle.
Old Dec 2, 2011 | 04:20 AM
kejobe's Avatar
kejobe
Ok, now I feel like a dumd*ss. I didnt even think to replace the factory 3" with a 4". I was thinking, ok, I need 1" but cant find one. Thank you, now I guess that makes you the smart*ss.
Old Dec 2, 2011 | 08:38 AM
LoneWolfArcher's Avatar
LoneWolfArcher
I am considering a leveling kit. Would you suggest 1" or 2" based on your experience?
Old Dec 2, 2011 | 12:27 PM
kejobe's Avatar
kejobe
Need to measure your truck. Measure from axle center to bottom of wheelwell lip. Difference between front and rear is how much lift you need. I needed 2", but it "looks" higher in the front, although measure the same now. Thats why I want to do 1" in the rear.
Old Dec 2, 2011 | 11:22 PM
kejobe's Avatar
kejobe
Top Gunz has a 4" block but says it's for 2wd. Aren't the axles and spring widths the same between 2wd and 4wd? Or would they not work because of something I'm missing?
