Fixed my transmission shuddering.. Guess what it was.. lol
Yes I read that. And that is exactly whats happening. truck shuddered a lot around 43 mph when od kicked in... but it has been softened by the "lube guard" stuff or coincidently for some other reason that shudder is not as bad when I drove it right after adding that stuff? it says it stops TC shudder so maybe its having an effect on the way the tc works and locks up which is helping to mask the misfire issue in this case?
Entirely possible.
If you aren't getting any misfire codes.... makes it s a little more fun to track down. How old are the cap/rotor/wires/plugs? Got the plenum done? (vacuum leak can give you a miss as well) Can you check pending codes?? Or misfire counters? (need a pretty good scan tool for that exercise.... not sure the parts store fellers will do that trick.)
May want to pick up a spark checker as well, and see what spark looks like. We had a member that had a crank sensor that was misbehaving, causing weak spark on several cylinders. (that was a learning experience for me..... I always thought that was an all or nothing affair. Apparently not...)
Entirely possible.
what is factory gap for our 96 ? ive seen everywhere from 40 to 50 on here?
I had a slight shudder when I had my ancient AP5224's in it. When put the factory Champs in it, it gained soo much power and the shudder when away. Put 3923's and rerouted the wires and it got better still, more power less knock.
I have to make a list of engineering weaknesses to watch for... lets see... plenum gasket,cracked heads, pinging, steering play, track bar balljoint, deathflash,lack of headlight relay...cracked dash..(oh wait thats 98 up
) transmission failure, stupid check valve, leaky bedlight seal non functioning cup holder,wild vents, LSD wearing out or grenading quickly fuel filter IN the tank
98-up yeah I know, but still, try it.
