318 Build
Old Dec 4, 2011 | 08:59 PM
ryan0714's Avatar
ryan0714
Default 318 Build
so guys i think im finally gonna drop some money, and i wanna try to get 300+ hp so im lookin for someone who is good at guessin horsepower. this is what i wanna do.
i have sct(93 tune),gutted cat, flowmaster, cai.
I want to install f1 air gap, headers, and bigger throttle body. how much would i net from all that?
later on down the road i plan on throwin on 1.7 rockers and a whiplash cam.what you think i would have after this? let me know the 2 figures please.
Old Dec 4, 2011 | 09:12 PM
crazzywolfie's Avatar
crazzywolfie
i don't think it would be possible to get 300+hp with those bolt on parts. i think you would probably have to stroke it and upgrade the heads with the upgrades you listed to get that 300+ hp you want.
Old Dec 4, 2011 | 09:22 PM
BIGRED97's Avatar
BIGRED97
i dunno what the numbers are, but i would say go ahead and do the hs 1.7 first and maybe the airgap later. everything i have read has pointed to the 1.7rr being the best bang for your buck 2nd to an SCT which you already have.
just my .02$ and i havent done either one but planning on it soon.
Old Dec 4, 2011 | 10:10 PM
Hahns5.2's Avatar
Hahns5.2
300hp at the crank or the wheels? At the crank that's not too unrealistic but it's gonna take a bit more than you're thinking to get there. You're going to need a cam and will probably sacrifice some low end to reach your goal, to get more HP you need to carry the torque higher into the RPMs, so you may want a higher stall convertor too. The stock heads are a big restriction, too.
Just a guess, but I'm thinking 260ish at the crank.
Old Dec 4, 2011 | 10:14 PM
Terribly's Avatar
Terribly
I think you have the right idea to get there but I think I would start with the rockers and cam, throttle body, and better flowing exhaust. With the engine being an air pump, that just seems to be the way to start with as a baseline. If you are wanting to go the bolt on route. Otherwise no replacement for displacement.
Old Dec 4, 2011 | 10:16 PM
silverlakexj's Avatar
silverlakexj
find a place with a dyno that runs on your wheels. I know when I built my Charger's engine, I have a place close to me, and if I added something, or tried something out, I would run over there and see how much good it did. I found that going there when the guys were bored got me some free help and they let me try a few things out to dial the engine in more.
Old Dec 4, 2011 | 10:21 PM
Terribly's Avatar
Terribly
Very good point! I should have suggested that too as my friend did that with his Subi
Old Dec 4, 2011 | 10:57 PM
ryan0714's Avatar
ryan0714
well i think im gonna do this all together. im gonna get the 1.7s, f1, TB, headers. the rest of my exhaust has been done. ill see what that stuff gets me. then down the road i could throw in the cam. and i forgot to say, i lookin to get the 300hp at the crank, at the wheels would be awesome but i knew that was a long shot.
