upgraded tranny cooler
Old Dec 15, 2011 | 03:31 AM
biggreen2500's Avatar
biggreen2500
Default upgraded tranny cooler
are there any upgrades as far as tranny coolers go for out trucks?
the stock one just seems a little to small. i tow alot with my truck so i figure a upgrade is a way to go
Old Dec 15, 2011 | 06:01 AM
peshewa's Avatar
peshewa
Tons, just look at JEGS & Summit or ebay.
Old Dec 15, 2011 | 04:44 PM
biggreen2500
i've never added a tranny cooler before and i'm guessing that most of them are universal fit.
Old Dec 15, 2011 | 06:07 PM
peshewa's Avatar
peshewa
Yes, you can order them with the barbed hose fittings or the AN fittings as well, and they all have instructions for installing them in 1 way or another. If you can do a tune up without breaking something, you can do 1 of these with no issue.
Old Dec 15, 2011 | 06:37 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Can you say "search button" ? B&M tranny cooler is probably the best.
Old Dec 15, 2011 | 06:42 PM
kejobe's Avatar
kejobe
There you go with that misterious word again.
Old Dec 15, 2011 | 06:46 PM
SilverSS's Avatar
SilverSS
+1 for the b&m. It bypasses the fluid when it's cold so it helps to regulate the temp to where it should be.
Old Dec 15, 2011 | 06:55 PM
zman17's Avatar
zman17
Besides that, you want one that's fin and plate not tube.
Old Dec 15, 2011 | 07:55 PM
dhvaughan's Avatar
dhvaughan
put the biggest universal cooler you can find on the front of the radiator. run 3/8 hose to it and use only auto transmission hose at about $3 per foot.
remove the check valve at the end of the hard line at the frame near the radiator.
i had a well known transmission guy poo-poo my plate cooler and replace it with a tube. said it flowed better, worked better, and was less likely to get stopped up because it maintained high pressure all the way through. the plate cooler sort of oozes the fluid through. it might have higher cooling capacity per size, but he still didn't like it.
here's some pictures for you.
https://dodgeforum.com/forum/2nd-gen...ter-added.html
Old Dec 16, 2011 | 03:29 AM
biggreen2500
i like that remote filter idea.. i'm still looking for a bigger size tranny cooler tho.. my buddy was telling me about some big ones you can get with e fans on them from B&M but no luck finding one yet...
what is the Check vavle?
