Trans groaning when temps are cold..
Old Dec 22, 2011 | 12:00 PM
Crackshot's Avatar
Crackshot
Default Trans groaning when temps are cold..
My trans makes a "groaning" noise when put in reverse when cold out and during winter.
After it is at operating temp, it is fine. It shifts fine.
In the summer it does not make this noise.
Any insight on this? 2001 Ram Off Road with 4 speed auto.
Thanks
Old Dec 22, 2011 | 12:05 PM
kadetklapp's Avatar
kadetklapp
Mine does it as well. I have a theory it's actually the drive shaft or the transfer case binding and not the actual transmission though. I could be wrong however.
Old Dec 22, 2011 | 12:12 PM
More than likely has to do with fluid flow characteristics when it is cold. If everything works as it should, don't worry about it.
Old Dec 22, 2011 | 12:25 PM
J415's Avatar
J415
I was thinking along those lines. Maybe the check valve.
Old Dec 22, 2011 | 12:33 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
What about checking the fluid level? Don't these really appeal to atf+4?
Old Dec 22, 2011 | 12:45 PM
offroadjosh's Avatar
offroadjosh
Try this...
crank heater fan on high and turn radio up works like a charm on my truck:P Noise goes away lol.
Old Dec 22, 2011 | 02:03 PM
Crackshot's Avatar
Crackshot
Thanks for replies. Yeah the fluid level is up to par and not burnt. Still has red to the fluid color,
I will probably take it in to trans shop my friend works at.
He said about 80 bucks they will dump fluid, change filter and adjust bands.
Probably would not hurt.
Old Dec 22, 2011 | 02:13 PM
I groan when it's cold in the mornings too.......
Old Dec 22, 2011 | 02:48 PM
Crackshot's Avatar
Crackshot
LOL. Was zero this morning. Trans line check valve was deleted last spring also.
