4 channel amp with tweeters
yea i would go with a passive external crossover, but depending on what kind of head unit you have you may be able to use the crossover built in. You would have to dedicate 2 channels for the tweeters only, and then 2 channels for the kappa's up front, and 2 channels for the rears. Perhaps run the rears off the radio rear channel, and then use the 4 channel amp for the kappa's and tweets.
Unless you're going for the perfect sound, a 10 dollar set of bass blockers will do the same thing as the crossovers in my 300 set of components. If all he is wanting to do is cut the bass out of them, the prewired one he has on there will get the job done. As far as the wiring in series or parallel goes, It drastically changes when you go beyong single voice coils. I scratched my head for an hour trying to figure out a set of quad voice coils one time lol.
Ok iPad was dead and computer is useless so I wasnt able to get on and read all this good info.....for that I'm sorry
Now just to give an idea on what I got going on.
1. I have the stock infinity tweeters in my front doors running off the radio power.
2. I have aftermarket tweeters in the back of the cab by the seatbelt running off of the rear speaker power from the radio
3. Front door speakers are 6x9 kappas and I'm running those off of the amp
4. Rear speakers are reference series 6.5 and those are run off the amp
5. 4-channel us acoustics 4065 amp, I was told it was a 60 or 65 watt amp per channel, it was free and started the whole thing. Wire is all 16 gauge speaker wire, except for 8 gauge wire powering amp
Now it is all done already and I'm having a problem I listen to it and it sounds great until I turn the radio up to 40 then it freaks out and starts with a high pitch screech then goes quite and does repeatedly till I shut the power off....any ideas....amp too small
