confused
Old Dec 30, 2011 | 10:34 AM
nomind's Avatar
nomind
Default confused
Ok so i got my buddy a 2001 ram 1500 and when i put it on stands it will shift thru all 4 gears but going down the road it wont come out of 2nd gear any ideas?
Old Dec 30, 2011 | 10:37 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Friction from the tires on the road.
Changed the fluid? Changed the diff fluid?
Old Dec 30, 2011 | 10:39 AM
nomind's Avatar
nomind
yes all fluids vchanged and topped up
Old Dec 30, 2011 | 10:40 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Governor solenoid and governor pressure switch.
Old Dec 30, 2011 | 10:43 AM
nomind's Avatar
nomind
that will stop it from shifting on the road but not on stands?
Old Dec 30, 2011 | 10:45 AM
Unplug the 8 pin connector behind the shift linkage on the trans, take the truck for a test drive. It will NOT have ANY automatic function. It should STAY in the gear you tell it to. (and no tcc either, i think....) If it shifts when you tell it to, and all the gears are there, drop the pan, and replace the governor pressure sensor and solenoid.
Old Dec 30, 2011 | 11:01 AM
nomind's Avatar
nomind
kk will do and let you know thanks again for all the help
Old Jan 1, 2012 | 12:18 PM
nomind's Avatar
nomind
ok so the trans was fubar so pulled it then put a known good one in and shifts fine but now it stalls some times when i put it in reverse it revs up then down and has alot of spark knock (crank sensor maybe)?
Old Jan 1, 2012 | 12:23 PM
zman17's Avatar
zman17
Could be, did you remove it first and reinstall it after.?
Old Jan 1, 2012 | 12:26 PM
nomind's Avatar
nomind
No i left it in (laziness) just trying to get this truck going for a friend
