transfer case shift pattern
Old Jan 7, 2012 | 05:12 PM
byronpen's Avatar
byronpen
Default transfer case shift pattern
had my transfer case rebuilt. after install. I cant seem to find the right set up for my floor shifter. I can get 2 wheel and 4 h, but not natural or 4 low. Any ideas
Old Jan 7, 2012 | 05:17 PM
sam_priem's Avatar
sam_priem
so when you try to put into neutral or 4L, the shift lever hits the floor preventing it from moving further back? or does it just not go into those gears?
Old Jan 7, 2012 | 05:43 PM
byronpen's Avatar
byronpen
no it wont even go past 2 wheel. it stops there. Im thinking i didnt properly set the shift lever. ive bee screwing with it for a few days with no luck
Old Jan 7, 2012 | 05:49 PM
sam_priem's Avatar
sam_priem
the only thing i can say is to keep trying to adjust it until you work out what ever is stopping it from moving. maybe someone else who knows a little more about the t-case will chime in.
Old Jan 7, 2012 | 05:55 PM
ADJUSTMENT - SHIFT LEVER
(1) Move shift lever into 2H position.
(2) Raise vehicle.
(3) Loosen shift rod lock bolt at trunnion
(4) Check shift rod fit in trunnion. Be sure rod
does not bind in trunnion. Lubricate the shift rod
and trunnion if necessary.
(5) Verify that transfer case shift lever is in 2H
detent position. The 2H detent position on the transfer
case shift arm is the second position from full forward.
(6) Align the adjustment locating hole on the lower
shifter lever with the adjustment channel on the
shifter bracket assembly
(7) Insert an appropriately sized pin through into
the adjustment channel and through the locating
hole to hold the shifter in the correct position.
(8) Tighten shift rod lock bolt to 10 N·m (90 in.
lbs.) torque.
(9) Remove the locating pin from the adjustment
channel and locating hole.
(10) Check shift linkage operation. Be sure transfer
case shifts into and operates properly in all
ranges.
Old Feb 6, 2019 | 12:58 PM
RDesmet's Avatar
RDesmet
So what does that shift pattern look like? I have a '94 Dodge Ram 2500 with the 5.9 Cummins Diesel. Is the shift pattern upper left 4H, middle left 2H, middle right N, and lower right 4L? My transfer case shifter does not have the button in the center of the shifter **** with the pattern on it. Thank you! -Bob
Old Feb 6, 2019 | 02:58 PM
HeikIlm's Avatar
HeikIlm
From front to back: 2H, 4H, N, 4L. They changed it in '98 IIRC, but can't remember that pattern.
Old Feb 6, 2019 | 05:09 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
4L N 2H 4H also in 98 it went in a straight line. Unlike in the older years when you had to go to the right.
