horn doesn't work and smoking! help!
Old Jan 8, 2012 | 03:14 PM
Tom Shepard's Avatar
Tom Shepard
Exclamation horn doesn't work and smoking! help!
hi there im having a problem. my horn doesn't work, cruise control doesn't work the airbag light is not on so im not sure if this is a clockspring problem or not? when i do try to honk the horn it seems to drain the power down some (lights dim etc). and the other day i was pressing one of the horn buttons and kept pressing it and i smelt a burning smell and smoke was coming out of my steering column right behind the steering wheel.
my truck is a 96 ram 2500 4x4 5.9L
thanks for any help im new to this site, you have helped me out a lot allready
Old Jan 8, 2012 | 05:10 PM
You have a short in the horn wiring somewhere, and probably too big of a fuse as well. Verify you have the right size fuse, then disconnect BOTH horns, and hit the button, see if the fuse blows... If it doesn't plug in one of your horns, and try again, see what happens, if that works fine, unplug that one, plug in the other one, try again.
Old Jan 8, 2012 | 05:46 PM
nomind's Avatar
nomind
that deffinately sounds like a clock spring
Old Jan 10, 2012 | 11:01 PM
Tom Shepard
thanks for the advice i'll try the wires as soon as it warms up outside
Old Jan 11, 2012 | 02:08 AM
peshewa's Avatar
peshewa
The wires in the tilt column are known for shorting out. What HeyYou said about too large capacity of a fuse is correct too. Get it fixed before a surprise BBQ happens!
Old Jan 11, 2012 | 06:47 PM
Tom Shepard
Smile solved
turns out my remote starter was wired wrong. power from the remote unit was connected to the horn.
cruise still doesnt work but i can live without it.
thanks for the help
Old Jan 11, 2012 | 07:54 PM
Does the lite on the steering wheel come on? (for the cruise.)
Old Jan 12, 2012 | 07:07 PM
Tom Shepard
no lights come on for the cruise control, but the airbag light comes on and goes off when i start it up, like i would expect it too.
Old Jan 13, 2012 | 10:50 AM
Gonna have to do some testing for the cruise then. May be bad switch, or clock spring..... or something as easy as a fuse.
