Top cigarette lighter works but the bottom one doesn't
Old Jan 9, 2012 | 09:55 PM
chadhager03's Avatar
chadhager03
Default Top cigarette lighter works but the bottom one doesn't
My top cigarette lighter works but the bottom one doesn't, it hasn't worked the entire time Ive had the truck. Does that one by any chance have a different fuse and is there an easy way to take it out? Also is there any common problems with it? Thanks
Old Jan 9, 2012 | 10:25 PM
CharlieSheenWins's Avatar
CharlieSheenWins
i'm having the same exact problem lol we both could use some help
Old Jan 9, 2012 | 10:28 PM
Vinny72's Avatar
Vinny72
the bottom one should be just a power port
Old Jan 9, 2012 | 10:30 PM
gdstock's Avatar
gdstock
They are fused separately. It is too cold and dark for me to go look and my manual is out back. Wiring diagram has it - that's where I found it when I fixed mine, but I cannot remember where or which fuse.....
Old Jan 10, 2012 | 07:18 AM
UnregisteredUser's Avatar
UnregisteredUser
The power outlet fuse is in the PDC, the cigarette lighter fuse is in the interior fuse box.
Old Jan 10, 2012 | 07:41 AM
chadhager03
Alright thanks I'll lOok today. I know there are quite a few blank fuses in the pdc.
Old Jan 10, 2012 | 11:16 AM
BIGBIRD85's Avatar
BIGBIRD85
mine did that that and i pulled out the ash tray and removed 2 screws and the faceplate comes off. the wires were unplugged on mine.
Old Jan 10, 2012 | 11:30 AM
CharlieSheenWins
^^ such a simple fix lol I'm checking that first
Old Jan 10, 2012 | 07:45 PM
BackwoodsRam's Avatar
BackwoodsRam
mine had a broken wire somwhere in the harness so i pulled the outlet and used the hole to mount a push button ignition
Old Jan 10, 2012 | 08:01 PM
rumble_truck's Avatar
rumble_truck
same, accept I cant just reach my hand through my dashboard and around my radio.
