Lift related talk
Old Jan 9, 2012 | 10:35 PM
Mutt Bryant's Avatar
Mutt Bryant
Default Lift related talk
I wasn't sure whether this belonged in the general discussion or here, but either way it's tech related so it won't hurt. My suspension is stock with factory blocks and springs. I got 33's under there on 16" rims with about 15 or so mpg. Stock gears too. I wanna know how big of a tire I can fit under the fenders (reasonably) without having to lift.The ones I got now scrub alittle btw. Also I wanna know how much it would kill my mpg to get the bigger tires. Any and all input is appreciate. Thanks guys.
Old Jan 9, 2012 | 11:11 PM
97ramrod1500's Avatar
97ramrod1500
well if the tires you have on now rub a little then it seems thats as big as you can go without having to lift. I believe 33 is the largest they can go stock. and generally bigger tires will reduce your gas mileage
Old Jan 9, 2012 | 11:47 PM
DodgeLooney00's Avatar
DodgeLooney00
My truck's pretty much identical and I have 33's on the stock 16's and I hear slight rubbing (Only on hard turns). all you need is a 2 inch lift and you'll clear 35's. BUt I agree, larger tires in general will decrease your mileage unless you re-gear....
Old Jan 10, 2012 | 11:29 AM
CharlieSheenWins's Avatar
CharlieSheenWins
if you have 3.55s then please dont put 35s on..stay with 33s and save our already temperamental transmissions...If you are willing to upgrade gears though, you can fit 35s with a 2" lift with the correct wheel backspacing
Old Jan 10, 2012 | 11:49 AM
99dodge318's Avatar
99dodge318
By brother 01 4x4 had 35" on completely stock suspension.
But I think the reg cab short beds sat slightly taller because of less weight
Old Jan 10, 2012 | 06:03 PM
Mutt Bryant
so you're saying that unless I re-gear it, I will put a good bit of additional strain on the transmission that will wear it down abit. If I put 4.88s in there, will it run good with 35's and not strain the trans to much (or strain my luck with the gas milage)
Old Jan 10, 2012 | 06:30 PM
mstephen89's Avatar
mstephen89
yep, you would love the power of 4.88's and 35's.
Old Jan 10, 2012 | 06:40 PM
Mutt Bryant
So what if i did a 3" body lift, 4.88's, and 35's?? Would it be worth it to go body lift? Am I gonna be stressing out any components too much?
Old Jan 10, 2012 | 06:41 PM
Up to 3", you can do suspension lift fairly cheaply. Spacers up front, and blocks/AAL's in the back. I am not a fan of body lifts..... Since you have a 3/4 ton, you could prolly get away with 2" of lift, and still fit the 35's. (heavier trucks sit a couple inches taller than the half tons from the factory.)
Old Jan 10, 2012 | 06:50 PM
mstephen89's Avatar
mstephen89
you could do it with a body lift. I would normally be with HeyYou, but lets say you do the body lift first, and run 35's for a while, then later you could step up to a bigger suspension lift and run much bigger tires. if you do a little suspension lift now, then you will just end up throwing away those parts later (if you want more lift later).
That being said you would probably only need a 2 or 3 inch spacer up front, which they are very cheap(alot cheaper then a body lift). as for the back, no lift is necessary, but the truck will sit a little bit bulldog, but some people like that.
