locker time..
Old Jan 14, 2012 | 06:38 PM
offroadjosh's Avatar
offroadjosh
Default locker time..
Locking at getting a locker for atleast the rear of my truck(probably rear for now). Want to stay cheap as possible and also want it to bolt in(ie same carrier). Eventually I will pick a set of d60s up and do gears and lockers in those. Until then though, need some ideas for a locker. Powertraxs? Detroit is to spendy i think.., lock right?
Old Jan 14, 2012 | 06:39 PM
Do you just want to replace the spiders? Do you have an LSD now?
Old Jan 14, 2012 | 06:47 PM
offroadjosh
Got the LSD now. yea believe most all replace the spiders?
Old Jan 14, 2012 | 06:50 PM
mstephen89's Avatar
mstephen89
cheap locker=welder, lol. I hear good things about detroit and arb, but they are both pretty pricey, never heard anything good or bad about loc-rite
Old Jan 14, 2012 | 07:01 PM
Not sure you can get the fellers that just replace the spiders for the LSD diffs though..... Might end up replacing the carrier in any event.
Old Jan 14, 2012 | 07:04 PM
mstephen89's Avatar
mstephen89
oh yea your right, loc-rite is just a replacement for the spiders right?
Old Jan 14, 2012 | 07:16 PM
Yep......
Rebuild your posi?
Old Jan 14, 2012 | 07:25 PM
offroadjosh
BLAHHH! Maybe a drop in lsd thats better?..
Old Jan 14, 2012 | 07:47 PM
I think you can rebuild the current posi with the carrier in place.... I think..... I do believe any other alternative is going to require yanking it, and replacing it, and having to re-setup your gears.
Old Jan 14, 2012 | 08:41 PM
offroadjosh
Will have to find out if i can do that. Might go ahead and do that. If i have that or pull the carrier ill rebuild and keep searching for a set of 60s cheapish. (soooo wish i had not sold the axles outta the wrecked 2500 i had!! Had lockers and 410s...
