Not winning the transmission fluid leak battle....
Old Jan 16, 2012 | 07:40 PM
  #31
stewie01's Avatar
stewie01
Originally Posted by zman17
You can get to the screw and replace the harness/solenoid assembly by removing a plate with a spring inside, on the side of the VB. Don't know what that plate it's called. Then just use a very thin putty knife to hold the spring in and replace that plate.
Thanks man! If I do decide to do it this will be my weekend project, instead of traveling north
Old Jan 16, 2012 | 07:46 PM
  #32
zman17's Avatar
zman17
Retired Moderator - RIP
So now you have a whole week to order a B&M drain plug.
Old Jan 16, 2012 | 07:57 PM
  #33
stewie01's Avatar
stewie01
And TCC/OD Solenoid. Think I might give the dealer a call tomorrow and see how much they are....
Old Jan 16, 2012 | 08:03 PM
  #34
zman17's Avatar
zman17
Your kidding right? In that case add in removal of VB to labor.
Old Jan 16, 2012 | 08:11 PM
  #35
stewie01's Avatar
stewie01
I meant order the part in post #17. Right?
Old Jan 17, 2012 | 06:35 AM
  #36
zman17's Avatar
zman17
Yea that's the part, but I'd clean everything first and make sure thats where the leak is coming from. The linkage can leak too, and that seal is replaceable from the outside.
Old Jan 17, 2012 | 11:13 AM
  #37
Wh1t3NuKle's Avatar
Wh1t3NuKle
Look for any other "soft goods" to just replace too. Additionally, I'd add studs/bolts/etc. to the list. Always good to come across breaking bolts as a part of disassembly or installation.... ask me how I know.
The worst part is discovering you need a part....and its not in your bag!!!!!!!!!!!!!!!!
Good luck bro. Pictures aplenty expected.
Old Jan 17, 2012 | 01:35 PM
  #38
stewie01's Avatar
stewie01
Welp, the truck is screaming it's outta gas and will be sitting until the leaking part is replaced, I'm gonna clean it up and verify the leak location before I go spending. I did call the local dealer, provided we're talking about the same part they have one in stock for $128.
I'm confident the leak is coming from the TCC/OD Solenoid Assembly but I'm TIRED of fixing the wrong part, so will be checking to be double sure.
Old Jan 17, 2012 | 06:51 PM
  #39
BigBlue83's Avatar
BigBlue83
Crab a couple cans of brake cleaner, and get all the crap off the side of the trans there. Clean as much as you can. Once it's all nice and clean, take it for a ride, then, follow the trail.
You guys all seen how mucky my dust plate was from the rear main seal and oil pan gasket i did. my tranny kinda looks really dirty like that the connector is pretty caked the way stewies is. how would i clean this with brake cleaner just spray it and rinse it off? or scrub with a brush as well? i want to clean it all but am afraid because of the electrical connectors.
Stewie: im glad your getting to the route of your problem good luck with the solenoid and Oring.
Old Jan 17, 2012 | 07:00 PM
  #40
Hit it with brake cleaner. (ignition OFF) no need to rinse. Brake Cleaner evaporates quite nicely.
