hmmm, i don't know. I can't see how not pluging in one side of spark plugs would have fried a pcm, but then again anything is possible. If it's trying to fire with the new pcm, maybe your sync is off a little bit, because didn't you say earlier that you messed with the distributor.
Maybe try moving the distributor a little at a time and see if you can get it to start. Either way you are going to have to get it re-synced right?
Since we're all guessing, I'm guessing you yanked the pejesus out of your timing chain and its either toast or stretched to the point its toast, and jumped a few teeth in the meantime..
drew, you think that the timing chain jumped time at the exact same time as he changed the headers? or because the motor was only firing of one side. I can kind of see it?
