changed header gasket now no start
Let me rephrase.
1. Turn the crank to check everything.
2. If something is off, such as cam gear off with rotor, intake valve on compression, etc.
3. Get the crank at the TDC 1 position.
4. Remove old chain, go through installation of new chain.
5. Recheck everything for TDC #1 using the intake valve compression as confirmation.
don't go spinning either one of them like it's cool.. we're going to cross our fingers you don't have to turn them hardly at all.. if you give them a spin like that big wheel on the price is right, your fuel sync is gone to hell in a hand basket.. let's try to keep it close enough to get you somewhere that can set it for you.. specifically, the cam..
Edit: and all of the plugs keep getting gas fouled (champion stocker brand)
Check the connection at the coolant temp sensor, verify it is clean, and tight.
Once it drys out (again...) Stomp the gas pedal to the floor, and HOLD it there while cranking. See if it wants to start...... or at least comes closer.
What I think is happening is the PCM is seeing engine temp as -40*, so, it is DUMPING gas trying to get enough in there to start. Holding the pedal on the floor should... put the PCM in clear-flood mode, and it drastically cuts back on gas......)
Edit: maybe I got a bad crank sensor, or I need a new cam sensor
Check the connections at both ends.... at the sensor, and at the PCM...... make sure you are getting voltage to the sensor, and some flavor of signal back out. (not sure what the resistance should be for whatever temp... but, I am sure there is a chart out there on the web somewhere.
I don't think the IAT can have that profound of an effect on mixture, but, it might be worth checking as well.
So far as I know, unless you have a dead short on some of your injectors, the ECT sensor is about the only thing that should give the symptoms you are reporting. Should be.........
