changed header gasket now no start
Old Jan 26, 2012 | 11:12 AM
  #211
Wh1t3NuKle's Avatar
Wh1t3NuKle
Originally Posted by BackwoodsRam
Its alive...turned out to be a combination of a weak coil and an over enthusiastic ECT
Edit: the coil was within limits according to the FSM, but I replaced it any ways because of my erratic spark
Me 2. The ECT is the engine coolant temperature sensor. It controls how much fuel gets dumped at start up.if it tells the PCM that its freezing cold then the PCM dumps massive amounts of fuel
Nicely done Amigo! You need more beauty sleep prior to tackling another header gasket change.
btw, was the change due to a leak? (i can't remember) if so, where was it?
Old Jan 26, 2012 | 12:52 PM
  #212
BackwoodsRam's Avatar
BackwoodsRam
The gasket was leaking at the #7 cylinder, but when I pulled the header off the whole gasket crumbled. Moral of the story is pony up the extra bucks for high quality gaskets
Old Jan 26, 2012 | 01:13 PM
  #213
Gary-L's Avatar
Gary-L
Veteran: Navy
Welcome to the club. If you replace the word "gaskets" with any future purchases your life will be much, much better.
Old Jan 26, 2012 | 01:18 PM
  #214
BackwoodsRam
Like hookers and blow?
Thanks for all the help everyone
Old Jan 26, 2012 | 01:19 PM
  #215
Somehow, a pressed-paper hooker just doesn't sound like much fun......
