Fuel Filter / Regulator
Old Jan 23, 2012 | 12:25 AM
  #31
Ramcountryboy's Avatar
Ramcountryboy
Ok, a check valve actually has crossed my mind, I would appreciate any updates on how difficult doing something like that would be
Old Jan 23, 2012 | 09:42 PM
  #32
1nordictom1's Avatar
1nordictom1
Regarding the regulator placement, referring to just what I have done in the past with an EFI set up. the regulator should be near the fuel rail, this will give you a constant pressure at the injectors, & will allow the pressure at the injectors to stay the same, no matter where you are in the throttle....
My plan would be to use a check valve at where the pump outlet exits the tank. Earls & Goodridge Performance hose companies make these, approx $40, w/ an approx. .2 psi pressure drop across the valve, if memory serve's me correctly........
NT
Old Jan 23, 2012 | 10:19 PM
  #33
merc225hp's Avatar
merc225hp
NT
Thanks for that info saves me some leg work.
Old Jan 27, 2012 | 06:07 PM
  #34
1nordictom1
OK,
just to keep the info flowing.....food for thought
This is from the FSM, for my 2001 Ram 2500
"Fuel pressure while engine running = 49.2 psi +/-5 psi"
"a properly functioning pump should pump 1/4 liter (8.5oz) in 7 seconds"
In a previous post, it was mentioned that the use of GM TPI pump might work, I have researched it, & either they meet the pressure requirement or the flow requirement, but not both together. let me know if I'm looking this up wrong......
NT
Old May 16, 2012 | 07:36 PM
  #35
alt-fuel's Avatar
alt-fuel
Default dodge have dead head fueling no return
Variable speed fuel pump ramps up with demand. I maybe wrong.
