Reverse lights
Old Jan 22, 2012 | 07:43 PM
mccart's Avatar
mccart
Default Reverse lights
So my reverse lights don't work when the truck is idling. They start working when you rev the motor, the higher the rpm the brighter they get til theyre completely lit up at about 3000.
What could this be?
Old Jan 22, 2012 | 08:12 PM
Check the grounds for the backup lights. Also check the neutral safety switch on the trans, I think that does reverse lights as well.
Old Jan 22, 2012 | 08:53 PM
gdstock's Avatar
gdstock
+1 on grounds and neutral safety switch does control the lights, but rpm should not be effected by switch.
Old Jan 23, 2012 | 01:02 PM
gertie240's Avatar
gertie240
Do your headlights get way brighter when you rev it up?
Old Jan 23, 2012 | 01:47 PM
mccart's Avatar
mccart
No they don't
Old Jan 23, 2012 | 04:05 PM
Pronk's Avatar
Pronk
If my headlights get brighter when i give the truck some gas what could cause that?
Old Jan 23, 2012 | 05:14 PM
Actually, its normal...... to some extent.
Old Jan 23, 2012 | 06:29 PM
Mutt Bryant's Avatar
Mutt Bryant
When you rev the engine the alternator spins faster and causes more power to go through the truck. Correct me if I'm wrong.
Old Jan 23, 2012 | 10:43 PM
Pronk's Avatar
Pronk
Yeah that does make sense, I've just never really noticed it on any other vehicle.
Old Jan 24, 2012 | 01:01 AM
otgarzā's Avatar
otgarzā
true but really unnoticeable unless you pay very close attention to it. its like those cars where the radio volume goes up as the car picks up speed.
