350 swap
Old Jan 23, 2012 | 09:40 PM
mstephen89's Avatar
mstephen89
i don't know, but it's an intresting thought
mccart's Avatar
mccart
Default 350 swap
I was thinking about doing a sbc 350 swap into my 97 half ton ram. I know I will have to fab some motor mounts and stuff but will the 350 bolt up to my dodge nv3500? And could I do an efi live or Holley EFI system instead of a factory Chevy throttle body and computer?
I know This is the wrong place for this but I thought maybe somebody one here has tried or done this. My reasoning for this is it is a lot cheaper for parts and to build.
Old Jan 23, 2012 | 09:41 PM
mstephen89's Avatar
mstephen89
lol now that's funny. I beat you at your own post.
Old Jan 23, 2012 | 09:52 PM
mccart's Avatar
mccart
How does that work? Lol
Old Jan 23, 2012 | 10:22 PM
The forum gets confused on occasion....... What's really funny is, quoting the persons post below you.... and answering it.
I was considering doing an LSx swap...... grabbing engine, trans, and t-case from a donor, and dropping it into the dodge. Trouble is, most of the gauges, especially on the 98 and up trucks, get their cues from the PCM.... the GM unit won't have a clue about that.
Old Jan 23, 2012 | 10:38 PM
mccart's Avatar
mccart
Would the 350 bolt up to the nv3500 or is the bolt pattern different between the dodge and Chevy? Also i would get a Chevy computer and stuff if I had to.
Old Jan 23, 2012 | 10:48 PM
No, you would have to get a different trans as well. Or, see if someone makes an adapter plate.
Old Jan 23, 2012 | 10:54 PM
mstephen89's Avatar
mstephen89
i'm sure there is an adapter plate. nv3500 is a pretty common transmission. and a chevy 350 is as common as a motor as you can get.
Old Jan 23, 2012 | 10:58 PM
mccart's Avatar
mccart
I looked for a few minutes but didn't find any adapter plates for a dodge nv3500 to a 350. Does anybody know of anywhere to look?
Old Jan 23, 2012 | 11:04 PM
mstephen89's Avatar
mstephen89
after a little bit of searching i think that some older 80s model chevys came with 350's and nv3500's i don't know if that helps but maybe you don't need an adapter and thats why you couldn't find one.
