CHanged Plenum ....Not fixed
Old Feb 1, 2012 | 06:14 AM
  #21
zman17's Avatar
zman17
Retired Moderator - RIP
HAHAHA, that's what I said to myself , when I first looked at the dipstick.
Old Feb 6, 2012 | 05:05 PM
  #22
Shaggy433's Avatar
Shaggy433
Well It has been a week now so here's an update....
I put a couple miles on it and it is still losing oil. I checked it Friday afternoon and it was a quart low. Maybe 150 miles since the oil change Monday evening..I'm dropping it off at the shop tonight and they will look at it tomorrow morning and do a compression test to hopefully figure out whats going on....
I'm quite nervous about what it will reveal but its time to start exploring my options for the worst case...If it is a bad ring in cyl 5, what should I do? Replace just the rings in just that one? All on that side? All?? And if it's a cracked head do I buy one new or two? Is it a good idea to put new heads on a motor with 115k miles? I searched around for that one but couldn't find a consensus on whether or not its a good idea...Price wise what's this gonna run me? 1000? 2000? I usually turn my own wrenches, but doing the plenum last week that was the furthest I have ever been into a motor and am scared to go any farther than that so this will have to be a shop job...
Old Feb 6, 2012 | 10:44 PM
  #23
gdstock's Avatar
gdstock
If it is rings, do the whole thing. Never replace just one set. If head is cracked, I would replace both. And some will say differently, but I have put new (rebuilt) heads on an engine with over 100,000 on more than one occasion, with no problem. It depends on what shape the lower block is in whether doing the top end is sufficient.
Either case, I would change timing set as well also.
If it was me, and I had time, I would build up an engine form a JY in the garage, and swap it when I had it complete. But this would be dependent upon whether you have the tools, time, and experience building engines.
Old Feb 6, 2012 | 11:03 PM
  #24
If they have to disassemble the engine to re-ring it.... might wanna just look at buying a long block, and just replace the whole thing, and be done with it. Probably end up close to the same cost, or less....
Old Feb 7, 2012 | 12:11 AM
  #25
gdstock's Avatar
gdstock
+1. If it is rings, then whole engine needs build. Pulling pistons and not doing mains and rod bearings would be foolish. But doing the top end if tha is where the problem is would be OK if bottom end was good.
Old Feb 7, 2012 | 02:58 PM
  #26
Shaggy433's Avatar
Shaggy433
Well the bad news was confirmed....Cly 5 had 15psi during the comp test....Added a little oil do run it wet and no change..They hooked up an airhose to it and spun the motor by hand and there was always air coming out of the exhaust so they think that the exhaust valve is toast. He was worried that it was STILL burning oil and thinks that the rings are shot as well...Price to fix it 2k for new heads or 4k for a Jasper motor.......FKNA great..
Is there any way that the stealership that I bought it from could have masked the problem for a few days considering it started all of this 2 days after I bought it??
Old Feb 7, 2012 | 03:05 PM
  #27
merc225hp's Avatar
merc225hp
2 Days after you bought it, how long have you now had the truck? I think it's time to get ahold of the dealer.
Old Feb 7, 2012 | 03:35 PM
  #28
stewie01's Avatar
stewie01
Need to check lemon law's in your state and see what you can do, I'd vote for a whole different vehicle, screw fixin' the motor, unless you're attached to it. But gotta see you what you can do first..
Old Feb 7, 2012 | 03:45 PM
  #29
Yeah, have a chat with the dealer...... see what they have to say.
There are better motors out there, than Jasper.
Old Feb 7, 2012 | 06:03 PM
  #30
Shaggy433's Avatar
Shaggy433
Talked to the dealer and they said that I bought it "as is" so I'm SOL. Doesn't seem like Ohio has any lemon laws that cover used cars....
Merc225hp I've had it since Dec 14th so just under 2 months
