dodge clunk
Old Jan 30, 2012 | 09:57 PM
laharve5's Avatar
laharve5
Exclamation dodge clunk
Im still new to this site and Having problems once again with my 99 dodge ram. The steering was just fixed alignment all great. NO slack or any movement with steering components. I have a clunk sound when going over bumps. on smooth roads its great. the shocks have no more than 5,000 miles on them. if i press on the left front fender i hear it. i also hear it if i push up on the fender. could it be my strut mount?
Old Jan 31, 2012 | 12:28 AM
97tn4x4's Avatar
97tn4x4
The lower shock mount torques to like 90-100 ft lb's or something crazy like that. Check those and it could also be control arm bushings but I'm guessing the shock mounts. Did it do this before the new shocks?
Old Jan 31, 2012 | 02:38 PM
laharve5's Avatar
laharve5
No it didn't make the noise before the shocks Were put on. So do you think I should have that side re-torqued? I don't use it for hauling or off road either.
Old Jan 31, 2012 | 02:39 PM
Yeah, hit it with an impact wrench. Your noise will go away.
Old Jan 31, 2012 | 08:51 PM
97tn4x4's Avatar
97tn4x4
Yeah the first time i saw the torque spec on those i fell out, thats alot for the shocks lol.
Old Feb 8, 2012 | 02:11 PM
laharve5's Avatar
laharve5
I dont have access to an impact wrench at home. i tried using a wrench just to see if it moves and the bolt spins with the nut. I'm assuming that's normal because the other side does also. wouldn't the bolt also spin with nut when using an impact wrench?
Old Feb 8, 2012 | 02:27 PM
Gotta put a wrench on the other side, to hold it in place.
Old Feb 9, 2012 | 11:41 PM
Wickedquick's Avatar
Wickedquick
check the ball joints? that was my major clunk issue
Old Feb 10, 2012 | 10:53 AM
19cuda73's Avatar
19cuda73
New Member
Probably not your exact problem but front sway bar links on my 01 Ram 1500 4x4 were WORN out and when I would roll on a parking lot it sounded like someone beating a hammer on the front axle. Cheap DIY fix too.
Old Feb 10, 2012 | 11:15 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
No, you're supposed to HIT IT WITH AN AXE!
