governor pressure solenoid/battery gauge drop
Old Feb 1, 2012 | 01:56 AM
chelios1368's Avatar
chelios1368
Default governor pressure solenoid/battery gauge drop
Ok so here's my issue. Driving home I noticed my battery gauge drop down to 8 and stay. I got off the highway then all of a sudden it was acting like what was described as a pressure solenoid issue. I replaced both the battery and alt. Still have both issues I started with. Is there any relation between the two. I have an 01 sport with the 5.2.
Old Feb 1, 2012 | 06:18 AM
zman17's Avatar
zman17
Retired Moderator - RIP
You need to have the charging system checked. Could be defective alternator. But also could be the regulator, which is in the PCM, for some unknown reason. Check all your ground wire's too.
Old Feb 1, 2012 | 06:50 AM
chelios1368
I should have mentioned before. My truck will start right up no problem. No dimming lights or anything and the volts wont drop until I put it in drive and step on the gas. When I do hit the gas it starts out like its in 3rda gear but reverse is tip top. I've already checked out what might cause that im just wondering if there could be a connewotion between the two. Maybe the bad pressure solenoid causing the volt drop
Old Feb 1, 2012 | 09:42 AM
I think if the solenoid was drawing that much power, you would see smoke and flames rolling out from under the truck. More likely I think is, when you put it gear, the motor shifts a bit on it's mounts, and pulls a ground loose.
Old Feb 3, 2012 | 03:26 AM
chelios1368
well after changing the battery and alt. and checking all my grounds it ended up being my pcm going. hopefully thats what caused my tranny problems. i got three codes from the tranny p1765,p1495,and p0753. picking up a new pcm tomorow. thanks for the input yall.
Old Feb 3, 2012 | 06:15 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
if you dont mind, then would share roughly what cost of the new pcm? Is it really a new one or a remanned one? I'm asking b/c I've come across a wide range of numbers. Feel free to PM if you like. thanks and glad you got your resolution...for the most part.
Old Feb 3, 2012 | 07:00 AM
chelios1368
I checked at advance auto and I can get a reman for 265 with a $70 core charge. Later today im going to check with the dealer just to see who can get it faster,if its new so on an so forth. I will keep y'all updated
Old Feb 3, 2012 | 10:59 AM
chelios1368
The only place that could get one for me was NAPA auto parts for $284 with the old one. The dealer was $800 and they can't even order one. Also NAPA is a reman pcm but the dealer was new. Hope that helps you.
Old Feb 5, 2012 | 07:32 PM
chelios1368
Ok so I've replaced the pcm,alt.,battery fixed a ground that was junk and getting codes p1765,p0753,p1495......im still where I started. Battery gauge still drops when I put it in drive and will eventually die. Im stumped
Old Feb 5, 2012 | 07:41 PM
gdstock's Avatar
gdstock
Did you look up the codes and see what they are?
