dry oil filter
Old Feb 5, 2012 | 03:05 PM
  #21
zman17's Avatar
zman17
Retired Moderator - RIP
That's all fine and well, but not for someone who changes the oil every 3 to 5k. Why spend the extra money? And a 25 micron rating? A Wix gets 21 and a Baldwin filter can do up to 12. Sure, they don't claim anything more than 3 to 5k . But who cares if you change your oil every 3 or 5.
Old Feb 5, 2012 | 04:19 PM
  #22
Gary-L's Avatar
Gary-L
Veteran: Navy
People who follow the 3,000 mile oil change rule are fools. It's as outdated as a black & white Admiral television set.
Old Feb 5, 2012 | 04:25 PM
  #23
Don't knock my TV. It still works great.
3K oil changes is more about peace of mind than anything else. I try and do mine between 3 and 4K, simply because by that time, it's getting pretty black and nasty.
Old Feb 5, 2012 | 06:50 PM
  #24
Gary-L's Avatar
Gary-L
Veteran: Navy
And I'll bet your Tin Lizzy appreciates it.
Old Feb 5, 2012 | 07:49 PM
  #25
townsley4's Avatar
townsley4
I change mine every 3K-3.5k miles. Going to pick up a different oil filter tommorow. Are mopar filters any good? I know some 1 who can get me some. And I believe 3K mile change is about right. The oil is pretty black by then. But I am willng to pay the extra few bucks for a functional oil filter. I don't trust fram anymore, but like said before it could happen to anybrand or filter. What oil do you guys use as well? 5w or 10w? Thanks for the replies
Old Feb 5, 2012 | 08:08 PM
  #26
Gary-L's Avatar
Gary-L
Veteran: Navy
State hopes to break car owners' habit of changing oil too often
The 3,000-mile oil change 'myth'
If anything, change the filter every 3,000 and the oil at 10,000 and top off as needed. The color doesn't mean anything.
Old Feb 5, 2012 | 08:11 PM
  #27
Hahns5.2's Avatar
Hahns5.2
FWIW I change mine around 8-9k (Mobil 1), motor should die any day now
Old Feb 5, 2012 | 08:26 PM
  #28
gdstock's Avatar
gdstock
I change mine around 7500 miles. DD has over 270,000 miles on it, no oil consumption, compression and leak down are well within spec.
Old Feb 5, 2012 | 08:29 PM
  #29
crazzywolfie's Avatar
crazzywolfie
that one article VW posted a link to says any vehicle made from 2002 or older should stick to the 3000 miles per old change.
So, how often should I change my oil?
It depends on your car's age and make, and whether you primarily use it for short distances or longer hauls. With vehicles built before 2002, "you should probably stick with a 3,000 mile oil change," says Huffman. For later models, "Cars.com experts split the difference" between 3,000 and 10,000 miles, offering a "best estimate" of every 5,000 miles for the "vast majority" of cars. For model-specific advice, check your car's manual, or this chart created by California's waste management board.
Old Feb 5, 2012 | 08:39 PM
  #30
EndIsNear's Avatar
EndIsNear
Yea, I change mine every 10,000-12,000 miles. I think Amsoil even claims you can run 20,000 miles between changes.
