Check engine light came on today
Old Feb 13, 2012 | 08:23 PM
sbrodacz's Avatar
sbrodacz
Default Check engine light came on today
On my way home my check engine like came on. I stopped at o'rileys. Here is what the code read
P0420
Catalyst system efficiency below threshold bank 1
Any ideas. I'm guessing 02 sensor but wanted to check with you guys first.
Old Feb 13, 2012 | 08:24 PM
It's telling you your cat isn't cutting the mustard. Fixed your plenum yet?
Old Feb 13, 2012 | 08:39 PM
kejobe's Avatar
kejobe
^^^Yup. I keep getting the same code. But my cat is gutted though.
Old Feb 13, 2012 | 08:59 PM
gdstock's Avatar
gdstock
I got that on my Yota a couple of weeks ago. Bought new sensots and new cat. Installed sensor, cat still in box in garage. CEL went away. I checked with scanner and upstream and downstream sensors were reading too close to same values.
Old Feb 13, 2012 | 09:15 PM
kejobe's Avatar
kejobe
Probably would be best to replace the sensor first to see if the light goes out. Be cheaper and easier.
Old Feb 13, 2012 | 10:12 PM
jswain's Avatar
jswain
May try the nonfouler trick if you choose to run with no cat. I'm assuming you have a pre and post cat 02 sensor.
Old Feb 14, 2012 | 09:27 AM
sbrodacz's Avatar
sbrodacz
The previous owner replaced the exhaust. I'm not sure if he did a full cat back or not. It looks fairly new. I know he replaced it less than a year ago. I have the paper work somewhere.
Jswain what is the nonfouler trick? I am not sure which 02 sensors I have. I'll do whatever. I just want the code to go away.
I have not looked under the truck yet. I got it in oct and have put less than 1000 miles on it since. I have been using it more lately due to work.
sbrodacz's Avatar
sbrodacz
Is it going to cause problems driving on it? I probably will not have time to look/fix it until this weekend.
Old Feb 14, 2012 | 10:05 AM
PapaG's Avatar
PapaG
If its just the sensor throwing a code then you should be ok to drive it until this weekend.
As far as the non-fouler trick here is the link to the DIY thread about it https://dodgeforum.com/forum/2nd-gen...converter.html
Old Feb 14, 2012 | 11:05 AM
sbrodacz's Avatar
sbrodacz
Hopefully its just the sensor then Thanks for the link.
