Fuel Rail Removal
Old 02-16-2012, 03:42 PM
i mow grass's Avatar
i mow grass
i mow grass is offline
Old 02-16-2012, 03:56 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,295 Likes on 3,042 Posts
Either will work for the fuel line, I initially bought one of those so I could do the trans check valve delete, but, because of the design, it wouldn't fit in the tight space.... I bought the 'right' tool, that only did 3/8ths line, and it worked for the fuel line as well.
Old 02-16-2012, 03:59 PM
stewie01's Avatar
stewie01
stewie01 is offline
Well in the South we like to improvise, took some sturdy plastic tubing that was the right diameter to do the job, cut it to size and bam, fuel line off!
But I'm cheap like that....
merc225hp's Avatar
merc225hp
merc225hp is offline
Old 02-16-2012, 04:01 PM
HeyYou is offline
That's what I have at the shop. At home, I have just the one nice little metal feller.
Old 02-16-2012, 04:08 PM
Gary-L's Avatar
Gary-L
Gary-L is offline
I'm a Certified Redneck Engineer....
Fixed it for you
Old 02-16-2012, 04:14 PM
stewie01's Avatar
stewie01
stewie01 is offline
Originally Posted by VWandDodge
Fixed it for you
Thanks man, I knew I was missing something.....
Old 01-05-2013, 12:55 PM
Dwatkins's Avatar
Dwatkins
Dwatkins is offline
whats the name of the cable that goes from trany to throttle body lever slide to get off i popped and broke it PLEASE..for my 99 dodge ram 1500 5.9 mag
Old 01-05-2013, 12:58 PM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
throttle valve cable (TV)
Old 01-05-2013, 12:59 PM
QuadCabLuv's Avatar
QuadCabLuv
QuadCabLuv is offline
Tv cable or kick down cable.
Quick Reply: Fuel Rail Removal
