**sigh** ABS speed sensor replaced.....still getting ABS & brake light
Old Feb 21, 2012 | 03:48 PM
zman17's Avatar
zman17
Retired Moderator - RIP
A $3000 code reader should pull a PO code , not a 36 code. A 36 is like OBD1. I'm sure you have , but have you tried the key tick?
Old Feb 21, 2012 | 04:20 PM
gdstock's Avatar
gdstock
It was a $3000 dealio, not code reader. That's all a dealio will get!
This is one of the reasons that I bought a Snap On MTG 2500. Reads tons of data that I didn't even know was readable. Too bad most of my vehicle predate even OBDI!
Old Feb 21, 2012 | 04:23 PM
Get the ESP module for your snappy scanner. All you have to do is get close, and it gives you data. Of course, it's a 20,000 dollar module........
Old Feb 21, 2012 | 06:26 PM
hillbilli's Avatar
hillbilli
Unfortunately ABS codes have to be read by an ABS scanner or an OBDII scanner that specifies ABS compatibility. Some ABS codes can only be cleared by ABS scanners, unhooking the battery will not work. I once let a truck set for 4 days trying to clear one. Best bet is to take it to a garage to get it cleared or buy a ABS only scanner for under $100. Either way, your probably gonna have to pay to clear the code.
Old Feb 21, 2012 | 06:50 PM
blackbeasst's Avatar
blackbeasst
yeah it was an all in one scanner that had an abs option, it threw the code 36 with the above error. he also was able to clear it out within the abs options
Old Feb 21, 2012 | 07:00 PM
blackbeasst
he just got it a couple days ago and was still learning about it. i bet it was this code:
C0236 - Rear Wheel Speed Signal Circuit Missing
Old Feb 21, 2012 | 09:27 PM
gdstock's Avatar
gdstock
That sounds more like it....Mine had a bad connection at the PCM when I got that.
Old Feb 22, 2012 | 07:51 AM
blackbeasst
so under the hood i go. what do i need to look for at the pcm to be able to find the abs line?
Old Feb 22, 2012 | 03:13 PM
zman17's Avatar
zman17
The ABS module may be bad. But I'd download the 01 FSM and start tracing wires.
Old Feb 22, 2012 | 04:36 PM
blackbeasst
ugh. i think for only happening 5% of the time, i think i'll ride it out for the time being
