Troubleshooting Help on Gas 2500 4x4 Transmission
#21
Ok, take two...
Fixya says that 85 shouldn't get ANYTHING with the key off, no continuity at all. I have continuity to + and - with key on or off. I tried to check continuity with b30 and got nothing. Assuming b30 is the 30 hole on the middle connector on the pcm. So there's a problem.
30 works as it should. Voltage with key on or off.
86 gets no volts with key object or off.
Diagnosis?
Diagnosis?
#22
#23
