help getting intake off
Old Feb 26, 2012 | 03:31 PM
cutthroatxxx's Avatar
cutthroatxxx
Default help getting intake off
Ive got all 12 bolts off&not even sure if i needed to but took of egr valve,all lines fuel rail etc&still wont come off feels like something on the back by the dizzy is holding it down am I supposed to pull the distributor?Any ideas would be GREATLY appreciated.
Old Feb 26, 2012 | 03:35 PM
Probably just stuck. Dist doesn't need to come out. Use something to try and pry it up to break it loose.
Old Feb 26, 2012 | 03:38 PM
cutthroatxxx
Im gonna go count my bolts&double check had to take a breather,found some burnt vac lines...hopefully I can get those knocked out&get my hvac back to normal.
Old Feb 26, 2012 | 03:54 PM
cutthroatxxx
It looks like a steel tube with a nut connected to pass side of intske.Any idea how to get it off?
Old Feb 26, 2012 | 03:55 PM
EGR tube. Heavy use of chemicals, and possibly heat...... and the right size wrench.
Old Feb 26, 2012 | 03:56 PM
cutthroatxxx
Dude your fast like batman&sh@*
Old Feb 26, 2012 | 03:59 PM
cutthroatxxx
Can I disconnect it from somewhere besides the intake?
From the exhaust manifold..... not sure which is easier to get at though.... take yer pick. See if you can get a new one for not much money, and if so, just cut it.
Old Feb 26, 2012 | 04:07 PM
cutthroatxxx
Yeah I just seen that on exhaust,Man I cant get this thing to budge&Im afraid on starting a fire if I use heat.With all the fuel&oil since the rest of the intake is off.
Old Feb 26, 2012 | 04:10 PM
Keep a CO2 fire extinguisher handy.... Or, if you can find a new one, just cut it, deal with it later. Exhaust flows thru there, so, the fittings tend to corrode, and basically weld themselves together....
