problems since plenum fix
Old Mar 1, 2012 | 09:22 PM
cutthroatxxx's Avatar
cutthroatxxx
Originally Posted by gdstock
Seems like I remaber a check valve on vac lines somewhere. If it is backwards it may cause issues, but I am betting a leak somewhere.
I had removed the throttle body when I did the plenum so I replaced the gasket...I though maybe the throttle body of maybe I didnt get the intake on right but I dont see any oil leaks so idk.I hope it isnt the intske.I guess I'm gonna have to get a smoke test
Old Mar 1, 2012 | 10:35 PM
jswain's Avatar
jswain
You could do the TSB test for checking the plenum to make sure you don't have a bad plenum leak and check the intake manifold itself for vacuum leaks with an unlit propane torch, etc. That would at least help rule out a major fubar in doing the plenum repair. I'd triple check all the vac lines first. I don't know about the EGR system, my truck doesn't have it.
Old Mar 2, 2012 | 12:15 AM
cutthroatxxx
Did the test again plenum is fine,went around intake&throttle body with the propane&git nada.
Old Mar 2, 2012 | 08:58 AM
Have you blocked the intake side of that pipe for EGR? If not, when EGR opens, you have a HUGE vacuum leak.
Old Mar 2, 2012 | 10:33 AM
cutthroatxxx
Ok did not know that,Ive been looking allover on how to correctly do an egr delete but I cant find nothing&have no idea what Im doing.
Old Mar 2, 2012 | 10:48 AM
If you already have the exhaust side plugged, get an EGR block-off plate, remove EGR valve, install plate. Yer done. The plate blocks all the ports, so, no more vacuum leak.
Old Mar 2, 2012 | 10:54 AM
cutthroatxxx
ok Ill go fab up another plate&post back with the results
Old Mar 2, 2012 | 10:59 AM
cutthroatxxx
&before I forget do I need to cap off anyof the vacuum ports on the egr?
Old Mar 2, 2012 | 11:56 AM
Just disconnect the main line from the manifold, and then plug the manifold port.
Old Mar 2, 2012 | 12:23 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
You know the drill.
