2000 5.9 shuts off, no codes
Update
OK, I changed the crank position sensor, the cam position sensor and, for good measure, went ahead and put in new plugs, wires, dist cap, rotor, and coil. Put about 60 miles on it with no problem.
Today, coming into work, it shut off again. Same deal. It shuts off, won't start up until about a minute/minute and a half later and then runs fine.
What's next....replace PCM? I found places where I can get refurbished ones for about $350 with warrenty.
Guess I'll just keep throwing money at it since it's not giving me any codes or hints as to what's causing this.
Sonny
Sonny
Sonny
Got any suggestions as to a test I could do within the minute that it won't start keeping in mind that I'll be alone and probably along side the road or in traffic?
Is there some kind of remote spark test device?
Sonny
Yeah, the nature of the problem DOES make it hard to diagnose.... by the time you get everything in place, it will probably fire right up.
If you aren't getting a CEL when you try to start it though, that indicates a problem with the PCM though..... either the PCM itself, or a power/ground issue. Check all the connectors at the PCM, and see what they look like, also, check the grounds.... If you don't already have one, grab a service manual for your truck from the faq section. Look at the connector pinouts to see which are power feeds, and which are grounds, and make sure they are ALL clean and tight......
Another test you can try, is tap on the PCM when the truck quits, and then see if it will restart.....
You can get a spark checker, and a noid light (for testing for injector pulse) at your local parts store. But, I don't know if you will have time to do the diag if you are alone.....
I will go through the wiring with a fine tooth comb when I have a chance and I do have a factory manual.
Thanks for all your help, by the way! The guys at the Dodge dealer weren't much help.
Sonny
Of course they weren't. They don't want to help you fix it, they want to CHARGE you to fix it.
Maybe the PCM thinks its bad, and feels a need to 'stand in the corner' for a bit?
ECM vs. PCM: Originally, it WAS just an ECM. (engine control module) Then, the trannies went electronic as well, and it became PCM. (Powertrain control module.) dodge went overboard, the the crazy thing controls, or, has its electronic fingers in damn near everything on the truck.... except the radio.....
Have you changed the battery? If you haven't its probably the battery, even if it seems good.
You can read my thread about the same thing here
https://dodgeforum.com/forum/2nd-gen...any-ideas.html
I basically paid to have the cam/crank sensors changed and was on my way for a PCM and then changed the battery with a new one, all was fine.
