tire size question!
Old Mar 4, 2012 | 01:27 AM
Jonathan Davenport's Avatar
Jonathan Davenport
Default tire size question!
Okay so I have a 98 dodge ram 1500. I'm running 7in suspension and 3in body. 10in total. I'm running 38's with PLENTY of clearance. And I'm just wondering if anyone would know the biggest tire i can run. With very little trimming.
Old Mar 4, 2012 | 01:51 AM
Jonathan Davenport
Default question!
Okay so i have a 98 dodge ram 1500. 7in suspension. 3in body. 10in total lift. I'm running 38's with PLENTY of clearance. & I wanna know what the biggest tire i could run with minor trimming....anyone have a clue?
Old Mar 4, 2012 | 08:39 AM
Anything over 35's on those axles is pushing it. They really weren't designed to tolerate the loads placed on them. Going even bigger is going to pretty much guarantee that you will break stuff on a regular basis. if you want to go bigger, you should do an axle upgrade first.
Old Mar 4, 2012 | 08:44 AM
zman17's Avatar
zman17
Retired Moderator - RIP
You'd want 4:56 gears too at least, no ?
Old Mar 4, 2012 | 08:57 AM
I should think 4.88 or even higher.... (numerically)
Old Mar 4, 2012 | 09:24 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
In the realm of about 42-44" for no trim. That is approximate with respect to your question. Bunch of other factors go into that.
It only takes 1x to break something and figure shiz out....
Old Mar 4, 2012 | 09:34 AM
BackwoodsRam's Avatar
BackwoodsRam
Go with a set of Dana 60 axles and a gearset in the range of 5.13 to 5.60 if you want to run 40's or bigger
Old Mar 4, 2012 | 10:35 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
this belongs int he 2nd generation RAM section, not off topic
Old Mar 4, 2012 | 10:42 AM
zman17's Avatar
zman17
He already started a thread in the 2nd gen forum! Please merge or delete this one. Damn
We have all been there but, geez. People really need to read before they post.
Old Mar 4, 2012 | 10:45 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
^agreed. (thread reported) <--- zman do this.
Responses are being down over here already: https://dodgeforum.com/forum/2nd-gen...-question.html
