Wanting to do a Cummins swap
Old Mar 6, 2012 | 10:21 PM
CornfieldKing's Avatar
CornfieldKing
Exclamation Wanting to do a Cummins swap
I have a 1996 2500HD 5.9 V8 that i would like to switch over to a cummins. It is a 5 speed. I was wondering if the trans would bolt up to a 12 valve 5.9 cummins? I know it has the 241HD Transfer Case.
Old Mar 6, 2012 | 10:51 PM
Nope. Would need a different bellhousing, (easy), and a different input shaft on the trans.
It's cheaper and easier to just sell your truck, and buy one with a diesel.
Old Mar 7, 2012 | 09:06 PM
Wombat Ranger's Avatar
Wombat Ranger
Your 5.9 mag nv4500 combination is a highly uncommon one. Think twice before letting it go...
Old Mar 8, 2012 | 12:30 AM
crawlin95's Avatar
crawlin95
Search blackhawk on pirate4x4 he did a cummins swap on his 1500 with a 5.9
Old Mar 11, 2012 | 08:26 AM
Free Range's Avatar
Free Range
I'd look into, if your set on swapping in a diesel, a 4bt Cummins. They're cheaper to acquire, weigh less, easier time fitting the thing in the engine bay, it's all mechanical (less wiring to swap), and with a few tweaks, can put out some good power. Just my
Old Mar 11, 2012 | 10:26 AM
Wombat Ranger
1) He's talking about a 12 valve, mechanical injection.
2) A 12 valve (or any 6bt) will drop right in on the stock v8 motor mounts.
3) Where are you seeing cheap 4bt's? I have always found 5.9's to be cheaper. Just out of curiosity...
Old Mar 12, 2012 | 10:19 PM
CornfieldKing
They can put out some power but I'm looking for a whole lot more power! I will probably just buy a donor truck and take what i need off of it and part ouot whats left over.
Old Mar 12, 2012 | 10:34 PM
Wombat Ranger
That's the best way to do it! Get one with an NV5600! You won't regret it.
EDIT: Never mind they didn't come with 6 speeds till the 24v period. So go NV4500
Old Mar 12, 2012 | 11:38 PM
matt72991's Avatar
matt72991
so just how rare is the 360 mag/nv4500/np241dhd combo??? cause i kinda want a 1500 with a stick.....
Old Mar 12, 2012 | 11:45 PM
gdstock's Avatar
gdstock
Not as scarce as hen's teeth....but pretty close.
