no reverse
Old 04-23-2012, 06:41 PM
gdstock's Avatar
gdstock
gdstock is offline
Back off the adjustment and with tiny fingers, push it back into place. Make sure it fits into the notch on the link. While holding it, push servo arm up against it to hold into place and then tighten screw to hold in place. Torque as recommended in manual. It takes about 10 tried to get it into place. I fainally used trans lube to help hold it in place.
(If you get it on the first try...I do not need to know...)
  #32
Old 04-24-2012, 08:31 PM
joshockey's Avatar
joshockey
joshockey is offline
dang! i ended up pulling the od unit and i wish i wouldent have because now it snt going back in and i dont have the special tool to line up all of the splines im glad in a way though because i got to see the everything and trans seems to be still in good shape. i have no clue where to get the tool but im tired now from pulling that unit in and out more than a dozen times.
Quick Reply: no reverse
