help truck wont start
hello all,im lookin for help got a 99 2500 with the 5.9 v8 was going down the road went to pass some one and couldnt do more than 25 mph, got it home shut it off now it wont start, so relpaced fuel pump, ect, crank, cam sensor, iac, map, cap and rotor, and spark plugs, used computer off a running turck, new timing chain and gears, new coil and still wont start, i have fuel pressure, compression and spark, all it will do is crank, every once and awhile when you put your foot to the floor and crank it will try to start, i have compresion anywhere from 100 to 120, blue spark, 50 psi of fuel pressure and it will hold it over night, it just wont run
any help is great
any help is great
Did you verify that you have 5 volts at your sensors. test at the TPS. if lower than 5 start unpluging sensors one by one until the 5 volts comes back. that sensor is the one to replace. Also double check the tps by metering at a different sensor for it.
If it isn't in the sensors on the motor.....say removing them all and still no 5 volts, try unpluging the transmission, chances are you have a burned solenoid that uses the same 5 volts. Retest.
There's alot of angles with this senario,since you changed so much, that can compound issues,but hopefully this will help narrow down a possibility.
[quote=neilsrpcustoms;2742190]Did you verify that you have 5 volts at your sensors. test at the TPS. if lower than 5 start unpluging sensors one by one until the 5 volts comes back. that sensor is the one to replace. Also double check the tps by metering at a different sensor for it.
yep there is 5.11 volts at all the sensors
which 02 sensor bank 1 or 2
yes i did rotate the distrbutor but i did but it back, and yes but i did put it back on tdc on compression, and after i but the gears on rolled it over and the timing marks came back together each time, and the crank sensors are the same length
Trending Topics
[quote=turbojimbo;2742860]
Do you have california emissions? If not, then there is only one pre-cat O2 sensor.
Not correctly.
Exhaust coming out from where?
